Old 03-19-2006, 12:09 PM
bugonwheels1 bugonwheels1 is offline
optimal rowing shell
Okay, so my question is, for a rowing shell (very large length/beam ratio) that will travel at speeds about 4-4.5 m/s (for racing), is it better to have a longer hull or a short hull, taking into account frictional and wave drag?
Old 03-20-2006, 02:59 AM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
There is an optimum length to beam ratio which will depend on many factors. Simple calculation of the hull cross sectional area immersed when in use will indicate a measure of the wave making resistance. Surface area of the hull skin that is immersed will indicate a measure of skin friction which is also a drag force. The greater the total displacement the greater will be both drag forces. A hull designed too short will have a large wave making drag compenent, while a hull too long will have excess skin friction, even though it has a theoretical higher speed potential. It is often impossible to drive the hull up to this theoretical speed due to insufficient manpower. Best policy is to study some proven designs and use a design that fulfills a similar purpose to what you intend as a starting point for your own design. Some very general rules would be as follows: Lighter displacement is faster. Narrow beam is faster. The least immersed cross sectional surface is faster. This means semicircular underwater sections are quicker than hard chine. Use actual length of existing designs as a guide. The very quickest hull shapes are also inherently less stable. As you can see there is no simple formula.
Old 03-20-2006, 07:51 AM
CDBarry CDBarry is offline
Rep: 132 Posts: 519
Look first at Saunders "Hydrodynamics of Ship Design". There are a number of subsequent papers in many areas. Note that Carl Scraggs and Bruce Nelson did some interesting work that considers the effect of the accelleration and deceleration produced by rowing, which actually has a significant efect on shell desigen.
optimal boat thickness grp.boat Fiberglass and Composite Boat Building 1 01-13-2006 02:13 PM
Optimal Specs for Marinas / Navigation SheetWise Boat Design 2 01-25-2005 07:22 AM
Optimal hull? Robbi Boat Design 14 12-22-2004 10:00 AM
Wooden Rowing shell Rendezvous Don Seales Wooden Boat Building and Restoration 1 08-11-2004 08:58 AM
Recreational Rowing Shell Willallison Boat Design 52 05-13-2004 06:59 PM
