Old 06-21-2005, 11:41 AM
nemo nemo is offline
Naval Architect
Rep: 137 Posts: 132
Opinions on scantlings
Hi,
I would like to get some opinions from you on the scantlings I've obtained on this runabout, as you can see in this preliminar .dxf file, which includes a floor stringers, web frames and bulkhead view, and a typical section.
The main dimensions of the boat are:
LOA 7 m
BOA 2.44 m
Weight 2150 kg (full load)
Corresponding Draft 0.44 m
Speed 38 kn (waterjet propulsion)
Thanks
Nemo
"water always knows better"
Old 06-25-2005, 08:45 AM
Naval Architect
Rep: 137 Posts: 132
No answers??
Old 06-25-2005, 12:53 PM
Rep: 1397 Posts: 7,215
I can't open the file. Do you need a special program?
Old 06-25-2005, 01:39 PM
CGN CGN is offline
Rep: 121 Posts: 547
Intellicad or Autocad or Rhino will open the file just to name few
Old 06-25-2005, 01:52 PM
fede fede is offline
Rep: 34 Posts: 281
Hi, there are a few things that look odd to me,first of all there are a few places where I see three layers of Wr 600 with no Mat between each layer.
To me it looks like you are a bit low on the core thikness with 10 mm,then I guess you shoud specify what core you are using.
Then E bx and e ltm should be a couple of biaxials from vectorply ?
If yes why e-bx and not e-bxm (with mat) and then you put E LtM that does have Mat ?
Looking for opinions on 1990 Sunray Infinity 2800 gocatz Powerboats 0 04-20-2005 09:04 PM
Twin Rudder Scantlings mishnish Boat Design 5 11-09-2004 12:11 PM
Plate thicknessand other scantlings for aluminium construction Willallison Boat Design 14 05-20-2004 09:11 AM
Opinions Please- does anyone have experience with... Cheetie Sailboats 8 08-15-2002 08:31 AM
opinions please 8knots Boat Design 13 03-16-2002 03:13 AM
