Old 10-12-2009, 06:52 PM
open30 open30 is offline
Rep: 10 Posts: 2
Open30Type....
I have decided after 4 years++ the boat i want to build.
I will from today start it...
I don't even expect the boat to be prefect, or win races...
I just want a fast racing type, that i can solo/2 person sail
long distances.
So i want a 30' boat, built like a open40 type. Open 30....
(don't care about the state of the class)
So here is what i have so far....
Here is one i like, but i don't think he can sale the plans with the wing mast, its a prod. boat.
http://www.vgyd.com/Open30CRCK.html
Wing mast
Keel system that i can raise/lower (shallow water sailing)
water ballast 4 positions.
Flip up twin rudders
I have building experiance in pre preg carbon, i plan
on building this boat with UV cure E-glass/Vinyl ester
pre preg.
http://www.epoxyandcarbon.com/uv-prepreg-fiberglass.php
If someone has experience in designing open class racing boats, that would like to own one let me know. You design it, i'll build the first boat, then let
you use the molds i make for your boat. USA designers.
Split mold build, female, vacuum bag.....
More to come after i find a designer........
Old 10-12-2009, 07:17 PM
Rep: 10 Posts: 2
This is the resin i will use to have the Uv cure Pre preg made
http://www.reichhold.com/composites/...plicationID=13
Not sure on the e-glass type yet.
Old 10-12-2009, 08:01 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Hey Open,
Welcome to the forum.
Is the type of boat you're looking to build an open and close case... or are you prepared to look a bit further ?
If you're looking for speed you may want to look at a multihull. There are some very nice ones and yes, they are more work than a single hull, but their worth will be more also. Other advantages also...
It's just a suggestion, it is you that will have to walk the walls of your boat
Regards
Fanie
Water ! Just gimme water !
