Old 12-19-2001, 07:04 AM
Peter H Peter H is offline
Registered
Rep: 10 Posts: 31
one boat
One of my boats
Old 12-19-2001, 10:34 AM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
As far as marketing yourself goes I doubt I can be of much help, but is there some aspect of megayacht design you'd like to discuss? What makes one megayacht better than another, in your opinion?
Old 12-19-2001, 11:42 AM
I'm going to suggest eliminating the fashion plates. They interfere with the view from the windows (ports) and with line handling. The overhanging decks can be made strong enough without them. I advocated this in the course of finalizing the Krogen 39 trawler yacht, and the omission was noticed and praised in a design review by the editor of Passagemaker magazine. I also like a split-level design with an atrium in the middle. It's easy for the decks to become too seperate, and it can become difficult to locate the person you want to speak with. These day's you'd end up calling them on their cell phone if they were on a different deck!
Old 12-19-2001, 12:59 PM
Registered
Rep: 10 Posts: 31
Thanks!!!
Thank you for the sugestions, i will get back with a new picture of the ship
Old 12-19-2001, 01:02 PM
Registered
Rep: 10 Posts: 31
Another boat
I have another boats with more windows hope you like it
Old 12-20-2001, 08:05 AM
Though rules are meant to be broken in cases, I think there's utility to being able to walk along a side deck, line to the dock in hand, from bow to stern, though I think it's O.K. to have to climb or decend some steps in the process as long as they're not too steep. This need not necessarily be possible on both sides, but I think it should be possible on one. Also. the freeboard of your yacht looks low to me for an ocean-going vessel, and while I'm not against long, the length looks out of proportion to me for a 3 decker.
The good news is that you're clearly a prolific, and I suspect fast, CAD draftsman, and this could get you a job with a yacht design or naval architecture office if you play your cards right.
Merry Christmas
Stephen
Old 12-20-2001, 09:03 AM
Suggested links:
My drawings of the Kadey-Krogen 39:
http://www.kadeykrogen.com/krogen39p...rrangement.htm
Luiz de Basto's site:
www.luizdebasto.com
Old 12-20-2001, 01:04 PM
Registered
Rep: 10 Posts: 31
Here is another boat
Hello!!
I dont just draw big boats like the ones ontop
this one is pretty nice except the window in the front
Old 12-20-2001, 01:15 PM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
For whatever it's worth, I tend to like the top and bottom designs, but the one in the middle I'm not sold on. Aesthetically speaking, I like simplicity and most importantly consistently. The problem I have with the design in the middle is that the bow with its curved areas doesn't seem to share much in common with the stern. I also sometimes like the juxtaposition of angled against straight ( |\ or /| ) but I find the / \ a little troubling as it tends to overpower the strength of the overall hull lines as well as the feeling of motion – it might be because the hull is pretty low for this length that this bothers me. Of course these are just my own opinions, but you did ask for feedback
Old 12-20-2001, 01:58 PM
Registered
Rep: 10 Posts: 31
Good said Jeff
I also think that the one in the middle is a little bit special but now i have come up with a real killer design
Old 12-20-2001, 02:39 PM
Interesting, Jeff; I think I agree except / \ can work if all lines converge on a couple of points above the boat rather than being parallel. That way they pull the boat together instead of fighting each other.
Old 12-20-2001, 03:08 PM
Jeff's Avatar
Moderator
You're right - I spoke too soon.
In your example I really like the fact that the two points give order to the lines. I think part of the genius of a good designer is to make things seemingly simply, so that everything lines up in one or more ways to form an overall design. I like discovering that there is an order behind the individual elements.
I also like that there are two points of convergence better than if there were one as it makes it feel as if everything is in balance but at the same time there is a tension there... a feeling that the distance between the points is appropriate for a design in motion. Logically I would think that I would not find fault with a series, but it seems to break down in practice. Also the aggressive bow in the second example above might be why I find fault with the converging angles in the middle design - it might be partially a consistency issue.
In school I remember many times bringing in an (architectural) model and the professor would literally tear off anything which was added on as an extra, as just "style", if it could not be justified by the overall concept or geometry. The idea was that perfection is achieved when nothing can be added and nothing can be taken away.
Old 12-21-2001, 05:33 AM
Registered
Rep: 10 Posts: 31
intresting
Hello again
with a little more practice it might be better boats, im planning do study design next year and hopefully that would help me dra better ships
/Peter
Old 12-21-2001, 06:04 AM
Jeff's Avatar
Moderator
Good - I think you will enjoy it immensely. I’m curious - how long have you been drawing boats & ships? Are you working mostly with just profiles to come up with new designs, or do you also work with plans? Have you done any 3d drawings or quick 3d vignettes? Don’t get me wrong – 2d drawings are a fast and efficient way to create and work new designs, but if you’re working with cuts and other complicated shapes and multiple layers, a 3d sketch might allow you to explore it further.
P.S. Don’t take any criticism above too seriously; just decide yourself if it fits in the “wow, I didn’t see it that way before” or the “it’s strange that someone else looks at it that way, but it’s always good to have another perspective” category and then file or use it accordingly.
Old 12-21-2001, 08:05 AM
I like your last one the best, Peter. It looks rather patrol boat like. Some people might not like that in a yacht, but I do. I think it's the most proportionate of the three, and it succeeds in conveying the energy and excitement that you seem to be after.
I would remind people reading this that the preliminary cartooning of an outboard profile is important, but ultimately a very small part of a complete yacht design. A thouroughly thought out custom yacht will have about L^2/4 man-hours of design/engineering time in it by the time sea trials are complete (L in feet). That means a 155 footer will require about 6000 hours or about 3 man-years of design and engineering, whether that's done by an independent naval architect, structural engineer or composite specialist, stylist or interior designer, the builder, suppliers, or some combination thereof. Also, the design will probably have to comply with classification society guidelines (ABS, Lloyds, DNV or similar), and perhaps U.S. Coast Guard and British MCA <http://www.mcagency.org.uk/index.htm> standards, certain IMO standards, and soon certain ISO standards.
Finally, I thought I'd just point out that the title of this thread is now something of a misnomer.
Auto engine marinization DIY Marinizing 231 07-01-2010 07:34 PM
Luhrs T-29 (1995) diesel inboard converted to outboard Iya Boat Design 13 03-07-2007 06:48 PM
High-Speed Waveless Boat waveless Boat Design 82 10-10-2005 07:01 AM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 10:08 AM
Concept Boat Design Contest Tad Boat Design 16 09-17-2004 10:13 AM
