| Old people can answer this question! : ) I'm trying to make a geometry file from a table of offsets that looks like it came from the 60's or 70's. Each entry is, for example, 4-5-4 - which I take to mean 4'-5 4/8" -because there aren't any occurrences of "8" or anything higher in the third column. But in some places, it adds a + or - after it, like "3-1-6+" or "6-11-6-" ... what does this represent? I'm guessing, plus or minus a sixteenth of an inch. Please help. And all, have a good weekend! |
| Plus or minus a sixteenth. |
| Alan is right and I'm not that old.
__________________ "The hand feeds the mind." Weston Farmer |
| The + or - sign typically means a 1/16", but more often then not it means a "smidge" more or less depending on which it is. Offsets produced like this are usually done by hand, so take them with a grain of salt or possibly the whole salt shaker, depending on the designer. In other words, these numbers will get you close, but actually fairing is done on the loft floor not on the drawings, plus it's not uncommon to find errors in the offset table. This isn't to say the drawings aren't fair, they probably are, but only in the scale they were drawn at. When you take a very sharp pencil line and blow it up to the size the boat will be built in (the drawing scale), it's not a very sharp line any more, but a big fat smudge of a line. This causes subtle errors and unfairness to creep into the drawings. This is one of the reasons you loft a set of lines full size. You'll catch these errors and straighten any unfair lines you sight down. Oh please, Whoosh. A mm? No one is building boats to those tolerances. Hell if you can make one side of a 40'er within a 1/4" of the other you're far better then most. A 1/16" is more then accurate enough, likely more then necessary and certainly more then you can see or feel in it's performance, hence the commonly accepted 1/8" limit on offsets. |
| Plus or Minus +/- may have been an acceptable error ratio in those dated offsets. |
| I'd imagine the designer who wrote down those particular offsets meant "up to a sixteenth" (otherwise, only plusses would be needed, and not minuses). Probably, you'ld get closer going one third of an eighth by eye. Lofting, you'ld be close enough. I don't think absolute accuracy is needed if the boat's lofted. The boat will be true to itself if ever so slightly different than its sisterships. So PAR's right, a smidge it is. A sixteenth is close, but a third of an eighth is closer, though I think it is called a scoche or a dight or a smidge. Finer gradations would be named after various hairs... |
| whoosh, You can convert my offsets to mm when you pry them from my cold, dead hands thanks all for your help, I'll go on the assumption that a "plus" or "minus" equals a +/- one-sixteenth of an inch. |
| My whole point is, regardless of what the table off offsets says, the lines need to be lofted. Pulling station molds from unchecked offsets will result in an unfair boat. The only ways to check the offsets are to loft or plug the offsets into a bit of software and generate lines from them. I can pretty much guarantee the resulting hull will not be perfectly fair, if produced exactly as the offsets recommend. I've lofted quite a number of boats now and none didn't require at least some adjustment on the loft floor. |
| Maths is never an exact science.
__________________ tomkane |
| just noticed this thread my grand dad used a similar number system you are right about it being in feet inches and eighths with the plus or minus being called out as strong or light depending Rasornic got it down my grand dad was insane about accuracy if he was in the boat house it was his way or the highway and that included my dad who was bigger than he but not quite as sharp with his tongue although you didnt always get the benefit of a warning if old Roby called something out strong and it didnt come to him with that extra sixteenth on it you might consider ducking depending on the day and who he was pissed off at |
| I've been part of hundreds of builds in some form or another. I've never seen tolerances anything close to the 1/8" typically found on offset tables. I once bragged about a 27' fishing boat I'd just built. The sheer was within a 1/4" of it's opposite side, when measured with a tape. I considered this as close as you could expect and am still quite proud of the feat. |
| The worst one I saw had a 4" height difference in the topsides, nicely finished, amateur built, he was very proud of his boat, he only found out when doing the rigging, the caps were diffferent.....in the water a blind man could see it. But you are right PAR, we never build symmetrical....human error or whatever, they certainly are not true, we all try, but....... I am CAD CAM manufacturing alloy plate boats in China at present, they are pretty good, but 1/8".....sorry, no way. In theory of course....but so is the world perfect, in theory....even Communism is......in theory.
| When you add up all the pencil thicknesses that get used during a build, an 1/8" is a miracle. |
| How about symmetrical underwater? Most boats have more dohickies on one side than another, even weight may not be distributed properly. Surely this has more effect against water resistances than a 1/8 of an inch. To me Boats because of the general weight and slow speed have a larger margin of error than a Aeroplane. But the forces are also much greater. Case in point rudders. A plane rudder is a simple, light thing on a boat the forces are greater. Of course that is comparing comperable size vessels. |
| This is an odd question but I need an answer | ConchoMan | Fiberglass and Composite Boat Building | 1 | 01-31-2008 05:07 AM |
| 2 years Ive tried to answer this question. | Frosty | Surface Drives | 38 | 07-12-2007 07:41 AM |
| does anybody have the answer | 1st timer | Propulsion | 7 | 06-03-2007 06:41 PM |
| Stupid Question-Really Stupid Answer | timgoz | Open Discussion: All Things Boats & Boating | 81 | 06-02-2007 11:58 PM |
| New guy here people, one question | pud | Boat Design | 11 | 05-24-2005 10:58 PM |
