Old 07-09-2009, 01:01 PM
GOTTABSOMEWHERE GOTTABSOMEWHERE is offline
Rep: 40 Posts: 63
OK.........take a deep breath (adding sail to houseboat?)
Has anyone put a sail on a HOUSEBOAT ???
Now keep calm don't flip out...........I'm not suggesting a cruise into open water b ut rather just some movement on protected water.
My thoughts go to the historic "GUNDALOW" in new england.
These barges were used ofr cargo hauling .
Think about it before you respond.
Old 07-09-2009, 01:23 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Sail
Other than the fact that a houseboat is a sail, of course you can put a sail
on one. But a kite would work better.
Tom
Old 07-09-2009, 01:51 PM
Michael W Michael W is offline
Rep: 10 Posts: 13
This is similar to the trawler design that I am building. This particular one is a GEORGE BUEHLER design built by Seahorse Marine. I was either on this one or on a sister ship in Seattle last year and was quite impressed. It is shown here with sails. I think you can get 2-3 knotts (not exactly sure) without engines and with engines you can certainly reduce your engine RPM to save fuel. Plus it works as a steadying sail. Not quite a housboat, but could give you some ideas.
OK.........take a deep breath (adding sail to houseboat?)-sedan-20sailing-4.jpg
Old 07-09-2009, 02:47 PM
elskimo elskimo is offline
Rep: 10 Posts: 6
Give it a shot. The only thing that you may want to consider is all the people looking at you saying wtf. But I think it would be cool.
Old 07-09-2009, 03:57 PM
Luckless Luckless is offline
Rep: 105 Posts: 163
Well, he might want to consider the effects on balance it could have and whether or not it is likely to tip itself over in the first steady wind. Remember a sail is a big lever, and the bottom of the boat has to be be able to counter the force along the sail and mast, and the boat itself has to be able to take the strain.
Most houseboats aren't exactly the best when it comes to even motoring around. I'm not sure I would want to join you on the maiden voyage, no matter how sheltered the water you're in.
Old 07-10-2009, 06:57 AM
dskira dskira is offline
Rep: 1305 Posts: 1,372
I think it is a great idea. In the end of the nineteen century, sailing house boat were commun site. I have other pictures which I will put in.
I think it should be more develloped, since these beautiful vessel went in complete oblition, and deserve a second chance.
Old 07-10-2009, 07:01 AM
Designed by Commodore R.M. Munroe in 1903
Old 07-10-2009, 07:15 AM
Rep: 501 Posts: 1,767
Slow. Make sure you have engine in case wind is blowing wrong way....
Make sure you don't over do it, it might tear your house boat apart, it was not design to take the loads. I sail generates a lot more power than you might think even if you boat does not move because of it.
Old 07-10-2009, 08:58 AM
Rep: 40 Posts: 63
Sailing Houseboat
Hey Diskera
I knew it .................If it could be done somebody did it !
I see you home is Maine............Hve you seen the 'GUNDALOW" ? I think
it's in New Hampshire. That's what inspired my thinking.
Like your ole' tyme pics.
To other responders...............DUH ! I wasn't thinking of putting a sail on a regular modern house boat but sometning more like a barge or canal boat.
The concept was to act as a "pusher " to augment engine power going upstream and primary power going downstream. I would like to navigate some of the great USA rivers.
Looked at motorsailers but thought them to heavy etc.
Any morre comments ?
Old 07-10-2009, 09:16 AM
apex1
Yes one, if you use a term in future, make sure you use the right one!
A canal barge isīnt a houseboat. And the pictures shown by dskira doīnt show houseboats! One shows a barge, the other a sailing vessel.
But we are familiar with the off topic pictures that self appointed "NA" provides.
Old 07-10-2009, 08:03 PM
well perhaps it is slightly of the subject GOTTABSOMEWHERE would like to discuss, but I think some kind of sailing houseboat can be rebirth as a fonctional hollyday residence on a coastal water, without the necessary performance of a modern sailboat.
The comfort in a real space, a flat hull, a low aspect ratio rig, a small engine and the possibility to do the canals, mast being on tabernacle.
The small engine for the canals when needed and the sail to enjoy a quiet ride during a coastal journey. A rather stable platform with perhaps two centerboard to don't interfer with the cabin accommodation, will allow the houseboat to beach, or close too.
The ultimate stability will be the difficult point. Using a rather high cabin trunk cabin as adding lateral buoyancy in case of knock down (happened here in Maine with one of the Windjammer, and she stayed flat on the water!) and ballast can be a safeguard, but that should be studied very carefully. It will be a balance between draft and aptitude. I think Moody have launched some 40' which looks very "houseboaty" with a modern high ratio rig, but I don't know if I am correct about the yard, it was in the Yachting World some months ago.
Any way, my two cents.
Old 07-10-2009, 08:15 PM
By the way GOTTABSOMEWHERE I forget something. You are talking to a "affecionado" of old house boat, I love them, steam, nafta, gazoline, diesel any kind until the Trumpy.
You can find a book, from were I took the pictures I posted above, called HouseBoat and HouseBoating by Albert Bradley published in 1905 by Forest and Stream, NewYork. Any good nautical antic bookstore can find a copy, you will pay around $60. It is an indepth information about sailing houseboat, and also the maginificient steam houseboat. The plans are something and the pictures are fantastics.
Old 07-10-2009, 08:21 PM
joefaber joefaber is offline
Rep: 10 Posts: 17
Some of what you're trying to do is discussed in
"Handmade Houseboats: Independent Living Afloat"
by Russell Conder (ISBN 0071580220).
It's 240 Pages cover the basics of houseboat history and design.
A large portion of the book covers starting point ideas on planning
the various aspects of the 'house' building. it's worth the $20.
Old 07-11-2009, 06:05 AM
Thank you JOEFABER, I didn't know this book, and seams very interresting. I am going to find and buy it.
Old 07-11-2009, 06:13 AM
I went to read the exerpt of "Handmade Houseboats: Independent Living Afloat" in Amazone, but unfortunatly he wrote mostly about stationary house boat, and I am not interrested in this kind of houseboat, only the one who can move by themself like aa boat with propulsion eather by sail or engine.
But thanks again.
anchoring in deep waters issac82 Boat Design 27 07-07-2009 07:40 AM
sail Interiors-34' sail,wood strip comp. Roly Boat Design 2 02-05-2008 07:53 PM
Breath of fresh air!!!!! grady Fiberglass and Composite Boat Building 26 09-25-2007 12:09 AM
Modified Deep V jfblouin Boat Design 4 02-14-2005 03:38 PM
catamaran vs. Deep V Armand Salese Powerboats 3 03-12-2002 06:29 AM
