#166
| Boston, I had no idea the sawn frames were that close together. That should be fine but you may not get much flex right on the frame. Wow ..that's a lot of frames. That sorta explains the 20000lbs without any ballast. Soak the planks in kerosene before steaming. Drive raw linseed oil into the wood w kerosene and turpentine. Get the book "Skiffs and Schooners" by RD Culler. He tells about pine tar, tallow and other wood building tricks and methods. A good read too. Eric |
#167
| cool Im a big fan of alkali stains and tonge oil thing is glue does not stick to tonge oil or however you spell that so it would have to be oiled after the fact deal is tonge oil is perfect cause there is no sanding before reapplication, just wash it down, let it dry, and slather on more oil. Must be real Tonge oil and not boiled. Otherwise it just sits on top I'll be using a lot of cherry and walnut ( both dam rot resistant ) as well as white oak. Planking material as yet to be determined but not ceder as Im slightly allergic to ceder I might also consider scaling it up to 5% taller 5% wider and 15% longer if it helps with the stability issues of just lengthening it. But I will not be cracking my head every time I move nor will I be living in a 7x7 room house. Simply not happening, combining the upper wheel house area with the aft cabin area seems the logical solution
__________________ I am skeptical of the deniers diatribe |
#168
| Pat Atkins turns out to be a really nice Gal, Had some really nice things to say about old Ted Brewer and also commented on the honest of my Na concerning altering the Atkins plan. Nice to know what I decent bunch of folks I'm dealing with. cheers B
#169
| well I spoke to Ted and he recommended that I stay to 10%. In which case its not really advantageous to also move the width and height. Also mentioned how most people just change it however they want to and then tell him about it later rather than run it past him in the first place, I think he appreciated me asking before I went and changed anything. He seems to be ok with the forward raking windows and recommended (before I did) that I extend the aft cabin. He did not object when I suggested that I wanted to play with the interior layout either so that was a plus basically I've bought the prints and am just waiting for them to arrive at this point I think I'm inclined to buy one more set of prints of another boat I'm looking at and then with all three in front of me I can guesstimate the build costs for each meanwhile back at the ranch I can be making preparations. I need to get the mill work going asap so I can have some stock to work from this winter cheers B
#170
| Boston, My favorite oil at this point is raw Linseed oli and Turpentine. Turp is said to have anti-mildew properties. And there is a mildewcide that is compatible with Linseed and Turp. Culler talks a lot about Kerosene in the bilge of new-builds. I would be thinking Raw linseed oil, Kerosene, Turpentine and mildewcide. Thats what I've got on my cap-rail without the kerosene. Easy |
#171
#172
| sure does pretty sure its the Ted Brewer Grand Banks 33 ( actually 32.75 ) stretched to 36 ( or 10% over original ) I just bought the prints its narrow enough to get down the road short enough to get down the road light enough ( minus all fluids ) for me to drive myself on my existing license and stout enough to make it out to the Alutions from the inside passage on a good day. That and I could make it through the Columbia Bar on launch day assuming my piloting skills are up to it speaking of which whats the requirements for a captains license on a boat of 36' like I said I'm buying 3 sets of prints that are all in serious contention and going to consider cost and what not from there while I make a few preparations to build anyway for as funny as it sounds I do appreciate the abuse as I know I've been down right retarded about making this decision cheers B
#173
__________________ "All one has to do is follow the plans and build in no permanent leaks." -Charles Minor Blackford, on the simplicity of building flat bottomed boats |
#174
| Im ok with that Troy I gotta admit this has been one torturous decision clearly I am not qualified to design my own so I have to rely on anothers design my first pick in design doesn't suet the water in which I want to sail soooo its all one big fat compromise and I'm not a very compromising person
#175
| just in from the pub by the way so Im feeling brave and will attempt to list the changes I have in mind for the Grand Banks 1) stretch hull 10% 2) keep the pilot house at its original distance off the stem 3) keep pilot house to its original length 4) use the entire 3'3" to lenghten the aft cabin 5) loose the two pilot house doors and go with one door opening to the flying bridge ok will list the rest later knda fading B
#176
| Boston, Mate, that is starting to look like "real" boat.....
#177
| I want a wood hull that will flex when I hit a rock, FORGETABOUT IT , the difference in speed at which you can "hit a rock" and the hull will resist by flexing , and the speed at which the hull will hole is minor. A lighter boat might lift , a steel boat may dent , but a set of water tight bulkheads is a better choice for most bouncing off rocks. FF |
#178
| Lmao Big tides up in the pacific northwest that and lots of rocks. Also lots of floating debris from what I gather so a good strong hull might just come in handy. If you look at the print you can see not only some serious collision bulk heads ( looks like they are intended to be water tight to me but I need to get the prints before I can say that definitively ) but also what might be enough room to make this thing positively buoyant ![]()
#179
| Choosing the right boat to buy is hard enough let alone choosing one to build. I don't have the patience in such matters. I shouldn't mention this but there's a boat at Shelter island that's very similar to the Elco(?) you lust after. If i had my cam at the time I'd have taken a pic Protected rudder and prop are perfect,an acquaintance made a very good living for many years repairing these after contact with rocks and logs. |
#180
I also have a guy lined up to render the mods into a 3d walk through model. I'm going with cherry raised panel deckhouses similar to the widgeon detailing but over ply for strength. I think, need to check the weight budget and stay within specs. I could keep the highly detailed stuff interior but it would be nice to throw some chrome exterior as well. maybe I'll stick to black walnut exterior trim over white panel sorta like what is pictured but darker and slightly more extensive and work in a serious cherry interior. Will get the prints off to the render'rs ( cant spell for **** anyway and I definitely cant spell that one ) and play with trim soonest right after I get the deck house layout down. for a place as rainy as the pacific northwest I want some windows so I will also be increasing the window area and compensating for the loss in seaworthiness with the use of some serious storm shutters. I was thinking custom bent aluminum diamond plate bolt on stack-able units for easy stowage that could be applied before any blue water voyaging. cheers B
| how hard to complete | ciac89 | Boat Design | 12 | 01-18-2010 11:12 AM |
| How will Climate Change change our boating world, and what can be done? | Grant Nelson | Open Discussion: All Things Boats & Boating | 21 | 03-29-2008 02:29 PM |
| New Boat-Need Help To Complete | dbcooper | Boat Design | 5 | 05-16-2006 09:00 AM |
| Cherry is Complete | WildCherry | Sailboats | 2 | 05-26-2005 01:54 PM |
| Building Pontoon Complete Plan | Omarh4 | Boatbuilding | 1 | 09-09-2002 07:21 PM |
