Old 03-01-2010, 01:01 PM
gregk gregk is offline
GregK
Rep: 10 Posts: 22
Ocean crossing by pedal power & autohelm advice
Hello: A quick update on my pedal powered ocean passage from Canada to Hawaii - photos from successful sea trials last week:
http://adventuresofgreg.com/blog/201...e-trip-report/
I would like to install a Raymarine ST1000 Tiller Pilot and I need some advice. According to the documentation, I need 18" of tiller when I connect the push rod. My small tiller 'handle' is only about 5" long. Extending this to 18" will move the tiller way into the middle of the cockpit.
The rudder handle is the chrome handle on the right hand side of the cockpit in this photo:
Does anyone know something about these autohelms? Will it still work if I only have 5 or 6" of tiller radius? Is there an electronic setting that I can use to adjust for this?
Thanks,
Greg Kolodziejzyk
Old 03-01-2010, 03:08 PM
Rep: 1493 Posts: 7,447
If it is shorter it will react too fast. You can adjust the gain down to compensate. Make sure you have enough movement for the throw of the autopilot. I believe it is 9" but check the manual.
Old 03-01-2010, 05:12 PM
GregK
Rep: 10 Posts: 22
What do you mean "enough movement for the throw" ? of 9"? My tiller handle is a radius of 5" and a total throw of around 5 inches or so.
Ocean Crossing In A Small Boat venomousbird Sailboats 59 06-30-2011 08:53 PM
Ocean Crossing Multi Hulls Used 42/45 Thoughts johnnymac Multihulls 5 10-27-2009 06:44 PM
is my boat safe for ocean crossing, one design schock marto Sailboats 16 06-06-2007 03:18 PM
Ocean crossing with motor-yacht phatzih Powerboats 78 12-28-2005 05:50 AM
Composite ocean row boat advice OceanRowSolo Fiberglass and Composite Boat Building 7 01-26-2005 08:53 AM
