Old 04-09-2009, 07:09 AM
mbhanoo mbhanoo is offline
Rep: 10 Posts: 13
OBO carrier
We intend to convert a panamax bulk carrier to a dedicated phosphoric acid carrier, which would carry phosphoric acid in alternate holds(1,3,5,7 holds). For better utilisation of the vessel, we propose to carry solid cargo in 2,4,6 holds. Is it required to have a cofferdam between chemical tank and cargo hold? Can anybody please clarify.
Old 04-14-2009, 08:44 AM
CHALKIAS CHALKIAS is offline
Phosphates is one of the most usual cargoes that bulk carriers carry. I don't think that the phosphoric acid is considered a dangerous good. You should check the IMO IMDG code. We designed a bulk carrier that can carry phosphates and we did not use cofferdams between the cargo holds.
Old 04-14-2009, 10:40 PM
Rep: 10 Posts: 13
Thank you. I checked in IMDG code as well as IBC code. Since phosphoric acid is a type 3 chemical, it does not require even double bottom & double hull. IBC code says cofferdam is required if it reacts in a hazardous manner with other cargoes in the adjacent hold.
Old 04-29-2009, 05:52 PM
Naviguesser Naviguesser is offline
In the future you can also look at the Chemical Data Guide, that may be helpful.
Personal Aircraft Carrier Toot Boat Design 184 07-18-2010 07:41 PM
Swift Solo #069 - For Sale: $5,000. OBO pritchaj2000 Marketplace 0 11-30-2008 09:16 AM
Modern Aircraft Carrier Dook Boat Design 105 10-20-2007 07:14 AM
Flatop (Aircraft Carrier) Decks RatliffFranklin Boat Design 8 05-09-2007 03:35 PM
Professional Livestock Carrier?..... Dangerous? Wellydeckhand Boat Design 21 04-23-2006 04:35 AM
