Old 08-30-2010, 11:10 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
With regards to the TW28. We're building one and should start sometime soon. IN the process of getting a bow shed up before the snow flies. Anyhow, you won't get the cutting files from the designer. Shipping a kit to Australia should be easy enough. They regularly ship to Europe. The plans are already lofted out if you can get a cheaper source of marine ply nearby. It'd take you a week or so to cut them all out.
According to my count there are 8 built or underway that we know of. Three of these were built in Turkey. Three more are in the works to start soon mine being one of them.
http://forums.bateau2.com/viewtopic.php?f=12&t=24412
The TW28 is a big boat for an amateur builder, no doubt about that. I've been planning mine for 7 years. We'll likely build the V10 dingy first for the practice and use it later as a tender for the TW28. Our plans also including stretching the TW28 to 31' 5" LOA. Power will be a Yanmar 4JH-TE we bought used w/300 hrs on it.
Any questions don't hesitate to ask.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 01-13-2011, 12:34 AM
ozflyer ozflyer is offline
Rep: 10 Posts: 12
Hi Marco1,
I see you've still got the Kubota... I'm interested, as in looking for one.
With regards to your project, what is the intended use and what is you budget for a DIY project?
Cheers
Joe
Old 01-13-2011, 03:24 AM
Marco1's Avatar
Marco1 Marco1 is offline
That's lunch right there
Rep: 227 Posts: 136
The DIY project got on the back burner. The cost of ready made boats has dropped so badly that I can not justify to invest hundreds of hours and thousands of dollars to have a bot in years (several), when I can buy one.
The (new) Kubota is now for sale. fully marinized and with a brand new PRM80 gear box 2:1.
Hooroo
Marc
There's only one corner of the universe you can be certain of improving, and that's your own self.
Aldous Huxley
Old 01-13-2011, 10:24 AM
WickedGood
That is a very Pretty looking boat. It is Way too short. If you added anouter 10 or 12 ft onto the stearn it would look and function much better and you would have a place to fish. Also you could incorporate a dive platform/live well with intergral hydraulic trim tabs into the stern adding anouther 4 ft. Maybe come in at 33-35 ft total with a 10-12 ft beam and a 3 ft draft.
Just by the looks the boat is crying out for a little Diesil engine like a Cummins 5.9 6 cyl. 400HP It would be econmical to run and would boggy scoot to 25 or 30 kts to get to where your going in a respectable ammount of time.
Also go wil a pair of saddle tanks. 100 gal on each side should give you a good days fishing range for a coastal inland cruiser.
And Encapsulate all the wood in clear epoxy for easy maintaince. Wood is good & Strong but a pain in the butt to take care of. be sure to foam core all the cielings and decks to keep noise down and make the boat unsinkable.
Old 01-14-2011, 02:47 AM
Marco1's Avatar
Rep: 227 Posts: 136
Ha ha, that is a good one. Take the little Noyo Trawler 24 foot and add 12 foot plus 4 swimming platform, take the 8 foot beam and stretch it to 12 ft. The 25 HP engine make it 400 HP engine. 200 gallon tanks and don't forget the epoxy. (I think the fuel tanks are too small.)
I think Glen-L would love your suggestions! As for me, to build a 40x12 footer exceeds the size of my shed and my own lifespan not to mention budged.
Having said that, it would be possible to buy and older 40 footer, let alone a 24 footer without mortgaging my life trying to build it.
My personal opinion of course.
Aldous Huxley
Old 01-14-2011, 10:37 AM
WickedGood
I like the stretch version of the 40. This is 40 Meters
Now thats my kind of little Skiff
LOA
120’ 7”
LWL
108’ 4”
Beam
27’ 11”
Draft
9’ 0”
Displacement
848,944 lbs.
Old 01-14-2011, 10:30 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
Marco1,
Manie's a smart man but I disagree w him. I think one should get 100% rpm at WOT and a 3400rpm, 3600rpm or 3800rpm engine is just fine. But you should get rated rpm at WOT. Also the power required for that trawler 28 is 25 to 30hp in my opinion. Four hp per ton is all that's required fo an average full displacement hull and the trawler 28 is FD. 5hp per ton and maybe 6 is ok but 7 is too much power. I have 5hp per ton in my Willard and almost always run it 700rpm down from max. An excellent engine would be the 3GM Yanmar (27hp). They are very popular in sailboats and can be found used. See if you can find out what to look for to determine if it's an easy boat to build. PAR and many others know what to look for.
Old 01-15-2011, 12:29 AM
Rep: 3125 Posts: 9,398
I have to agree with Easy Rider all the way down the line on this one. An ideal setup is a "full pull" hitting target RPM with the prop(s) and other equipment selections at WOT. Anything other then this means you can make an adjustment somewhere. The 3GM is a fine engine, easily serviced and parts are world wide.
I'm not all that familiar with the Noyo design, except that it's a plank on frame, probably heavier then it needs to be and wow, she's got to move a huge volume around that forefoot. Considering the complexity of the forefoot shapes, some cussing is going on to get those planks to lay down. Anything can be put inside a hull with this kind of volume and she will be reasonable stable and fairly easy on here crew. Her D/L ratio will be in the 270's with a 1,000 pound load. I can think of much worse shapes, to get caught out in a storm with, though this isn't one I'd like to be in if a storm happened by either.
I guess it depends on what you want from this gal and how much weight you add, making it what you want.
Old 01-16-2011, 09:44 PM
Marco1's Avatar
Rep: 227 Posts: 136
Thank you for all your kind replies. I had completely forgotten this thread if it wasn't for a question sent to me about my kubota engine.
I still like the Noyo Trawler by Glen L, it is plywood on frame not plank and according to those who have built it, not too hard to pull it off and would be ideal for my river setting on the Hawkesbury.
However lately my idle time has almost dissapeared and so has the possibility of building a boat. Furthermore after a few successful attempts at importing boats from the US I discovered that with today's prices building would be very expensive in comparison.
Aldous Huxley
Glen-L or Clark Craft indyillini Boat Design 5 12-17-2009 04:15 PM
Glen-l squirt bman1985 Wooden Boat Building and Restoration 4 08-01-2009 08:56 PM
Glen-L TNT rgardn12 Wooden Boat Building and Restoration 4 05-06-2009 08:31 PM
New Book by Glen-L lewisboats Wooden Boat Building and Restoration 2 02-17-2009 09:36 AM
My first look at Glen-L plans !! Baldur Boat Design 10 06-29-2005 08:29 AM
