| Nonairbreathing Propulsion Attached is a patent describing rocket motors based on using the common industrial chemical furfural as a propellant. |
| Ok and why is a 1940 patent on what is basically an unusable alcohol fuel in a rocket engine important to boats/ships/maritime industry???????? K9 |
| *******es |
| I suggest you re-read your PDF file and the Wikopedia chemical make up of this product. But it still dosnt answer the question. K9 |
| Chemicals and ****** Quote:
F U R F U R A L does not spell F U R F U R Y L. F U R F U R Y L is the ALCOHOL DERIVATIVE of F U R F U R A L. |
| Patton Number# 2,835,106 Filed July 20th 1946 Quote from Wikepedia " Its chemical formula is C5 H4 O2. In its pure state, it is a colorless oily liquid with the odor of almonds, but upon exposure to air it quickly becomes yellow." Its dirivitive is an alcohol. Its the H4 that gives it its combustion properties just as in alcohol. K9 |
| Ok........so.....the point? |
| Brickwalls Quote:
| Chemistry |
| Quote" Furfuryl alcohol cannot be used as a monopropellant. Nor can it support combustion. Because IT'S A FUEL." Are you on drugs????? As you say, a FUEL CANNOT support combustion??????!?!?!?! What do you use in your car??? Jello? K9 |
| Dumbshits OXIDIZERS support combustion. FUELS are just the substance that burns. |
| I will agree, that to burn a fuel needs an Oxidizer... So again, whats your point here? K9 |
| Nonairbreathing Propulsion My point, in your case, is irrelevant since it requires some minimal comprehension of a variety of nonairbreathing propulsion systems having been studied for marine applications, mostly torpedos and submarines. |
| Your ability to influence people is beyond reproach. I can certainly see why you have a total of 2 rep points. Have a nice day. |
| Hydraulic Propulsion | Jmarkley | Propulsion | 42 | 02-29-2012 11:22 PM |
| Propulsion | DEDave | Boatbuilding | 7 | 02-19-2009 11:52 PM |
| propulsion | rasorinc | Propulsion | 6 | 01-01-2008 08:56 AM |
| DC propulsion | DGreenwood | Electrical Systems | 5 | 01-12-2005 12:47 AM |
| Hydraulic Propulsion | Jmarkley | Boat Design | 6 | 10-07-2004 07:21 AM |
