Old 01-04-2010, 08:14 AM
kayaker50 kayaker50 is offline
Rep: 39 Posts: 33
No 30 ft + sailing garveys?
I'm thinking a 30 foot garvey would provide more cabin space than a similar size sharpie, but a couple of days of prowling the net hasn't produced a single design.
1) is there a compelling reason not to build a garvey?
2) can anyone direct me to a source of plans?
Thanks, Chip.
Old 01-04-2010, 12:22 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
If a Garvey is a scow from New Jersey....how about this? Harry II is 30' by 8' 6" and draws approximately 12" with the boards up, designed for plywood construction.
Old 01-04-2010, 02:07 PM
narwhal narwhal is offline
Rep: 45 Posts: 68
Tad, that design resembles a Chinese coastal junk with its bow transom. All it needs is a pair of eyes painted on the sides up at the bow.
Old 01-04-2010, 03:18 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
What is the exact definition of a garvey? The only one I can find - "the chines don't meet at the stem" - is also a good description of a pram. I have a book somewhere with several "garvey" plans - none remotely close to 30' - which all have transom bows with the flat bottom transitioned into the transom by a radius instead of a chine as in a regular pram.
Dances with Turkeys
Old 01-04-2010, 04:05 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
In American Small Sailing Craft Howard Chapelle writes extensively about Garvey's. He uses the word interchangeably with scow, garvey connotes just a small scow from New Jersey (and very specific areas of NJ).
Old 01-04-2010, 07:20 PM
Rep: 39 Posts: 33
Thanks for the drawing, Tad.
My total knowlege of garveys is Chapelle's American Small Sailing Craft. He has lines for a 26 footer, cat-ketch rigged.
He describes it as an example of a scow that was refined locally. From his drawings, I assume a garvey to be:
flat bottomed
transom stern
low freebord
centerboard
the rocker forward is exagerated such that the bottom blends into the bow in a graceful curve. The drawings seem to indicate there is no real transom bow, but rather the bottom blends into the bow.
I've also read somewhere that the presence of the garvey in Jersey prevented the sharpie from widespread adoption there since they are both simple workboats.
Like the sharpie, it seems several hull forms wear the name that don't fit the classic description.
As I said, I'm thinking about a garvey as a competitor to the sharpie because it may offer more cabin space which is a weak point of the sharpie. If that were the case though, you'd think they would be more popular. But sharpies seem to be a dime a dozen with garvey's all but extinct.
Chip.
Old 01-04-2010, 08:39 PM
aka Terry Haines
Thank you K50 for a good description of the garvey, that is precisely what I see in the book I have. The curved bow transom would exhibit pounding than a pram and perhaps have greater strength. For a boat built with a cross-planked bottom it would be easy to implement, just the slight complication of bevelling the planks at the bow transition, but with ply construction the pram and skiff forms would be easier to build and perhaps this explains the relative rarity of the garvey.
Dances with Turkeys
Old 01-04-2010, 10:26 PM
Rep: 418 Posts: 777
I think of a garvey as a scow/pram type hull designed for either sail or more commonly power. I've seen plans for power garveys built of plywood. One of the magazines dedicated to small boats had an article and I think plans for a small power garvey 15 years back or so. Small Boat Journal or something similar. I think I recall mention of power garveys in Natl. Fisherman magazine but that would have been 20 yrs back or further. Not much help I imagine but somewhere they are available. Check out some of the books by John Gardner.
Old 01-04-2010, 10:53 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Below is a typical sailing garvey from Chapelle. Note the flat bottom is carried right up to the deck forward.... He states (writing in 1951) that no boats of this type are currently sailing. There's a reason for that...I can see they might be okay in flat water...but these boats would be horrible in any sea...that square entry will stop you dead.
Modern garvey's are all planing powerboats, and they all have some vee in the forward sections. My sailing scow above also has lots of vee in her forward sections to create a finer entry.
Old 01-04-2010, 11:58 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Attachment 39173
I wouldn't be too quick to dismiss sailing garveys. Chapelle commented that sharpies never took hold in the Barnegat Bay area, because they already had garveys. I assume there's a little bit of rough water in the area?
I'd give a quote directly from his book, but it's in my pickup and it's cold outside...by California standards and the way I'm dressed, anyway....
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 01-05-2010, 08:19 AM
Rep: 39 Posts: 33
Turns out "Mr Sharpie" himself, Ruel Parker has a design for a 28 footer:
http://www.parker-marine.com/G28page.html
Old 01-05-2010, 01:59 PM
frank smith frank smith is offline
Rep: 154 Posts: 672
Attachment 39145
Attachment 39146
Attachment 39147
Tad, that remind me of Bolger's AS29 blended with a little Maurice Griffiths .
Old 01-05-2010, 02:16 PM
Rep: 154 Posts: 672
most of his designs are old designs adapted to ply construction .
65 ft sailing cat Mark.D.C Multihulls 18 11-03-2009 10:06 PM
D4 / D5 Sailing Dinghy dominic Wooden Boat Building and Restoration 3 09-15-2006 04:42 AM
Can sailing take off in Dubai?! Saf Open Discussion: All Things Boats & Boating 0 09-05-2006 02:53 PM
SAILING channel yipster Open Discussion: All Things Boats & Boating 6 12-27-2004 08:37 AM
Very very new to sailing chrysus Sailboats 15 10-09-2004 09:03 AM
