| New type of Sailboat I am working on a design of a new type sailboat with a few unique features. I am looking for any advice on the best way to proceed. 1. Are there boat type engineers or software that will assist with the design? 2. Are there companies who will manufacture a prototype for me? 3. The initial version will be made out of injection moulded plastic - should I make the first one myself out of fiberglass? 4. Are there companies who will quote me budgetary volume prices for injection moulded boats? Any advice, comments very much appreciated. I am located in Wasaga Beach, Ontario, Canada |
There are plenty of valid persons on this forum, many of them professionally involved in boat design and building, and some others which are experienced sailors, so they all might give you a lots of good advices and indications, just ask the right questions. You are in the right place. ![]() Any hint on principal dimensions/characteristics of the boat? |
| Thank you very much for your advice. I realize I am at the very starting point with all this. Preliminary dimensions are approximately 11 feet long by 5 1/2 feet wide. Boomless, roll-up type sail. Peddle back-up propeller possibly and/or optional electric motor. Initial version for cruising not for speed. |
| A prototype could be made from cedar strips and epoxy or molded from fiberglass and your choice of resins over a foam plug, in addition to several related variants, but definitely not injection molded. Injection molding is how the finished product might be created cheaply in mass production. The roto mold is hideously expensive whereas the other methods mentioned are within the grasp of most backyard builders. I live near Old Town Canoe Co, and I once saw one of their roto molds at the metal scrap yard. It was a work of art, looking like a canoe sculpted out of stainless steel. I tried to imagine what it must have cost to build it. A hundred thousand dollars maybe. |
| thanks...what is a foam plug and how would I obtain one? |
The clamping pressure for an injection mold for a boat 10' x 5.5' would be far more than the largest machine I have personally seen (2000 Ton). The molding machine for a part that size would have to be about the size of a 2 car garage, if not larger. An injection mold for a hull like this would cost more than you could ever recoup by selling some 10 foot dinghy. Never mind the cost of the machine and/or the hourly rate to run parts. Roto molded parts will be made of some sort of olefin (PE or PP), and those materials are not condusive to secondary bonding, so it is not a great solution for most sailboat designs. Injection molding can use more structural materials like glass filled nylon, but even so it is not substantial compared to FRP. |
| what technique does a plastic type manufacturer of kayaks use..if it is not injection moulded what is the process..sorry for my ignorance here. |
| new type of sailboat | Ron Skelly | Sailboats | 4 | 11-20-2009 09:29 PM |
| what type of transducer ? | luso | Metal Boat Building | 1 | 03-09-2009 10:45 PM |
| What is the best exhaust location on a CCA type sailboat? | bntii | Sailboats | 4 | 02-21-2008 12:30 PM |
| Type of sailboat for the job? | Wellydeckhand | Sailboats | 10 | 05-18-2006 07:38 AM |
| Which type of wood????? | william23 | Materials | 1 | 01-16-2006 04:45 PM |
