Old 03-02-2005, 05:49 PM
Ron Cook Ron Cook is offline
Rep: 27 Posts: 66
New to the metric system
Hi All,
I am new to the forum and new to the metric system. I should have become comfortable with it a long time ago, but I guess better late then never.
It all seems straightforward except for the Newton. Is there a correlation between 9.81 Newtons per kg and the acceleration of gravity at 9.81 m/s squared?
Thanks,
Ron
Old 03-02-2005, 06:07 PM
boby boy boby boy is offline
owner of cla boat design
Rep: 10 Posts: 32
I do Believe so.
signed boby boy
make life fun :)
Old 03-02-2005, 07:10 PM
Skippy Skippy is offline
Rep: 12 Posts: 568
Right, the Newtons would be the weight. W=mg.
Old 03-03-2005, 04:27 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
For practicality, say g=10 and density of water=1 (1kg/l = 1000kg/m3).
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 03-03-2005, 11:43 AM
clarsen123 clarsen123 is offline
Metric is a whole lot easier than English, just break down everything into it's component units, string them along and see what cancels out. Much fewer funky multipliers. Actually, a Newton is a measurement of force N=(kg*m)/s^2, or can be described as Force=mass*gravity as the previous post says. It's another way of stating Force=mass*acceleration, where the acceleration is gravity (9.81m/s^2). If you divide a Newton by a kg, the mass (kg) units cancel, leaving you acceleration with (m/s^2) and the 9.81. Weight is actually a force W=m*g, not to be confused with mass, which exists even in zero gravity, and what causes intertia. Here's how I set up the equation. Hope this helps!
N
kg
kg * m
kg * s^2
m
s^2
Old 03-03-2005, 08:26 PM
Rep: 27 Posts: 66
Hay Guys,
Thanks for the metric system input, yes it helps. I know I wil have more questions later.
Ron
Autopilot System for Sailboat taobsu Boat Design 0 08-09-2005 01:41 PM
Alarm System yipster Boat Design 10 08-10-2004 04:26 AM
Chopper/Wet-Out System (Magnum/Venus) cla17 Marketplace 4 08-02-2004 01:00 AM
geometry of sailing Sailboats 8 10-12-2002 11:58 AM
Yachtica Integrated Systems yachtica Materials 0 03-28-2002 08:34 AM
