Old 10-28-2003, 06:58 PM
New jet propulsion system
Does anyone have any comments on the new outboard
diesel jet propulsion unit. www.jetpac.us ??
Old 10-28-2003, 07:21 PM
Willallison's Avatar
Rep: 2280 Posts: 3,467
my first impression is that the unit is rather heavy - at 428kgs its significantly heavier than say Mercury's 150hp o/b (193kg). It's a bit lighter as Mercrury 2.8L diesel (150hp) but as it's bolted to the transom (rather than inside the boat) it would have a more significant effect on the LCG
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 10-28-2003, 07:40 PM
RE Heavy
what about it being an automotive engine and no prop?
Old 10-28-2003, 07:51 PM
I only had a very quick look at the site, but I would be very surprised if it isn't marinised properly. Most so-called marine engines are derived from auto (or truck) engines, so I wouldn't see that as a problem.
As for jet vs. prop - that's a whole topic in itself - depends on the application, budget etc etc etc. But if I was looking for a 150hp diesel engined jet propulsion system, I'd have a look at it, but as I said before - the weight so far aft would definitley be a concern.
Will
www.imaginocean.net
Old 10-28-2003, 08:04 PM
Nomad Nomad is offline
Mold Trader/Boat Builder
Rep: 12 Posts: 462
The pack does float it's self rather well. The test ride was impressive.
Old 10-28-2003, 08:10 PM
I am going down to IBEX and than to the Ft. Laud show and
I will take a ride and let you know. You said its heavy but it is self
bouyant, and where its mounted evens out the c of g. i will
give my feed back once I test it
Old 10-28-2003, 09:03 PM
I take it you've been for a spin then Nomad - what else did you think?
I'm assuming that since it can be fitted to any boat with a deadrise of between 5 & 22 degrees, only a small area (including the pick-up) is in contact with the water when the vessel is on the plane. And, unless it creates enough of its own dynamic lift to remain 75% self-supporting (manufacturers claim) when it's on the plane then the LCG will be affected.
I'm not saying that it's no good or doesn't work - merely expressing my concern at placing so much weight aft of the transom....
Will
www.imaginocean.net
Old 10-29-2003, 12:48 AM
BVI Jon BVI Jon is offline
Rep: 10 Posts: 15
Looks interesting, but is it going to possably be limited to boats:
a) with a shallow "V" or less,
or
b) boats that only operate in reasonably calm water.
Jon.
Old 10-29-2003, 10:21 AM
MUST BE GOOD IT WON THE INNOVATION AWARD AT IBEX 2003
Old 10-29-2003, 02:45 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,267
sure makes me wonder about -outboard- jetdrives again...
Old 10-30-2003, 04:28 PM
handling
i live in the town where they make these JetPac's and have been out on both their boats fishing. All I can say is the KeyWest 196 is a shallow water fishing machine - its amazing how well it handles at slow speed making finding fish in the shallows a worry free experience. As for the offshore capabilities, the 275 gas JetPac had more than enough power to travel in 3-4 footers off of keywest, but I was not impressed with the ride of the Angler 220, Trims tabs could help that tho. Personally, my next boat will not be prop but a JetPac.
Jet propulsion possible for slower boat? mik lenoir Propulsion 5 09-24-2005 04:15 PM
steam jet propulsion engines Guest Open Discussion: All Things Boats & Boating 12 01-26-2005 10:32 AM
Another new propulsion system DEDave Boatbuilding 12 09-09-2004 11:25 PM
Low Drag Propulsion System Thunderhead19 Boat Design 5 05-25-2004 11:41 AM
Gas turbine/Water jet propulsion peter fisher Open Discussion: All Things Boats & Boating 1 05-12-2004 09:13 PM
