  #31
Old 05-25-2010, 12:46 PM
DrCraze's Avatar
DrCraze DrCraze is offline
Rep: 20 Posts: 91
Originally Posted by Joe Petrich View Post
"The entire aluminum superstructure burned/melted down to the steel deck." My bad. Al burns at 6920 F. If you have a fire that hot on board your boat I guess you have other things to worry about.
Like whether you have enough buns for your dogs? Or if your SPF is high enough
  #32
Old 05-25-2010, 11:25 PM
apex1
All very interesting.
All not very much informed....
Al burns from a lighter!
Steel burns from a candle!
Who is idiotic enough to compare a plate of either material with a mesh, foam or "wool" ?
AL foam can be ignited whith a lighter when carbon content and O² is present.
Steel wool can be as easy ignited when the same (high carbon, high O²) concentration is present.
Can you imagine a engine room with a throughput of just 30m³ of air per minute?
The "new" Al foam in question here, has nothing to do with boat or shipbuilding, thats it.
As nobody would assume that any sort of other metal foam or "wool" would have. They burn like hell.
Regards
Richard
  #33
Old 05-26-2010, 08:39 AM
aka Terry Haines
Rep: 1814 Posts: 3,009
Now we wait for someone to try it on a sailboat.
Dances with Turkeys
  #34
Old 05-31-2010, 08:11 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Aluminium core in jump ski's (water)has worked great for 30 years.
Aircraft/F1/18foot skiffs( when in their expensive mode)/water skis,thats the order for common usage of new composites as far as I can tell.
As for cheap composites that would be production recreational boat building where anyone can do anything they like.
( like use balsa with polyester non bagged layup)
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
where to buy foam core material rapscallion Fiberglass and Composite Boat Building 4 09-02-2007 01:11 AM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 10:12 PM
which core material ? aldo Boat Design 8 10-26-2005 07:37 PM
Transom Core Material Aaron23 Fiberglass and Composite Boat Building 4 01-07-2005 10:10 AM
Polyurethane as Core Material Victor Lemmi Materials 3 07-03-2004 01:39 AM
