Old 10-03-2010, 08:21 PM
Rep: 501 Posts: 1,767
New Dingy design . Want some inputs
I am design a dingy for my boat. This is not your average dingy.
MY SOR is coming. Here are some very rough sketches to discuss some concepts. New Dingy design . Want some inputs-flats-dingy1.jpg
Old 10-03-2010, 08:33 PM
SOR for dingy.
Dingy will fit into my boat sideways into/unto transom so dimensions are going to be critical. It will also have to be symmetrical.
So dimensions are:
Length: 15 feet
Width: 6 feet
Height: 1.5 feet
To be made from Aluminum.
Faceted look like Wally Boat
As light as possible
Driven by either outboard that is removable or perhaps small diesel jet drive.
Capable of being used as a dinghy, small flats fishing boat or for crossing a small bay.
Possibility of being used as lifeboat.
There will be flotation compartments and removable fuel tank.
Should be able to carry 6 adults in displacement mode
or at least 2 adults and some cargo in planing mode.
Outboard probably something like a 25hp two stroke
Anything else you guys might think about. I have about 6 months before I start serious on it. So starting to talk about it now.
Old 10-03-2010, 08:44 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
MY SOR is coming. Here are some very rough sketches to discuss some concepts. Attachment 48235
Attachment 48236
Attachment 48237
Attachment 48238
Put a little concave in the bottom fore and aft direction will help with going in a straight line ! also the very aft end of the bottom have a small 1 inch step 90 degrees all way across the bottom to break the surface of the water as it gets on the plane or it could suck the back down as the speed increases
Making beautiful boats is a passion never a chore !
Old 10-03-2010, 08:52 PM
Two good points - thanks
Old 10-03-2010, 11:53 PM
Rep: 3125 Posts: 9,398
Stop by the local Lowe's/Depot and pick up their largest concrete mixing tub, install a deck and call it a day.
Old 10-04-2010, 05:58 AM
Rep: 756 Posts: 3,328
Every operator of this may not be highly skilled .
I would round the sharp corners , and pad them well.
FF
Old 10-04-2010, 06:08 AM
FF
Of course, this is just a sharp rough draft. thanks
Old 10-04-2010, 06:13 AM
Built a boat similar to this before to use as workboat to stucco seawall, and it was a giant mixing tub. It would carry about 20 bags of concrete. The transon was square on it and sides vertical but the basic box was 8x4 plywood with an extended nose. We used it or 3 years and actually ran pretty good with with a 5hp engine.
I want to see you guys opinion on its performance. Being a double ender, with the engine inside the transom. What do you all think of ruby hull shape. Come on guys, I was expecting greater critiques. How would I calculate displacement on this?
Old 10-04-2010, 06:14 AM
I had strakes on bottom of my last tub, would those help here.
Old 10-04-2010, 08:16 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
As to the displacement...divide it into 3 parts...the box middle and the two triangular ends. Find the displacement of the box then find the volume of the box created by the vertical edge of the box times the waterline length to the junction of the angle and the waterline and the width of the boat then divide by 2.
edited...oops I didn't re-look before and now I see it has flare too. Simple...just a bit more work. Find the vol of the triangular sections of the flare the same way as you would the ends.
Old 10-04-2010, 09:52 AM
I see no advantage to the steep rake on the ends. You could nearly double the displacement speed by taking advantage of her length. The volume of a shape like this is fairly easy to calculate. Preform an accurate weights estimate and see where she comes out.
Old 10-04-2010, 10:23 AM
idkfa idkfa is offline
Rep: 66 Posts: 232
The sides are set at 45deg? beam at deck 6', at bottom 3'?! That makes standing on the gunwales or ends of thwarts very unstable.
Given that there will be no obvious reason for the slant, she'll look weird at best.
Old 10-04-2010, 06:09 PM
Perhaps that is a little extreme. I will change to a less pronounce amount.
Old 10-04-2010, 06:15 PM
Let your desires and design goals establish the size and shape of the hull form.
Old 10-04-2010, 07:50 PM
The problem with this boat is that it has to fit against my transom. I will try to draw picture of it.
Classic Tender / Dingy Design allan white Boat Design 7 06-14-2008 06:39 AM
Discussion- Multipurpose Onboard Computers: Human Inputs - Human Outputs TerryKing OnBoard Electronics & Controls 6 12-04-2007 07:51 AM
dingy sailer's benmww Stability 9 01-16-2007 04:49 PM
Design-a-dingy (to fit the deck of this boat) Seafarer24 Sailboats 0 01-10-2007 11:24 AM
Heavy weather capable dingy design zorton Boat Design 8 07-07-2002 11:51 AM
