Old 04-13-2007, 10:55 AM
SURRYEQUIP SURRYEQUIP is offline
Rep: 10 Posts: 5
New Concept for thru hulls, etc.
I was approached with the concept of putting all underwater gear, depth finder, knotmeter, thru hulls on a folding arm which would be faired into the hull when down and completely out of the water for service, no chance of leaking and no fouling etc. when not in use. Has it ever been done and what are the pros and cons as you see them.
Old 04-13-2007, 02:17 PM
mcollins07 mcollins07 is offline
Rep: 144 Posts: 202
I am not clear on what you are proposing. A sketch would be nice.
Are you suggesting a configuration similar to a swing keel? Where you would need a trunk of some sort?
Old 04-13-2007, 07:14 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
Where does the "arn" & all the gear go when the thing is folded?
Also, read up on depth sounders some. Yhey don't like other "things" close to them. Turbulence, air bubbles and such play hell with clear readings.
You MAY be talking about a sea chest. They work good on boats 30' or larger.
Yeah, we need a sketch.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
My concept blared Boat Design 14 08-07-2005 01:27 AM
design concept seadragon Boat Design 2 06-17-2005 09:09 PM
concept 40 Raymond Fourie Sailboats 0 11-06-2004 05:14 PM
new concept. Boat Design 1 12-18-2001 07:15 PM
new concept. Projects & Proposals 0 11-03-2001 07:54 PM
