Old 05-16-2011, 01:53 AM
ND Design ND Design is offline
Rep: 10 Posts: 4
New Boat Projekt
Hello.
Me and about 10 other sailors are doing a project
where we will build a monohull for racing with references to VO 70.
we are in design phase and look at all the ideas we can get,
the plan is to race it in all the distance races we can.
so come with all the ideas you have about:
Hull, sails, everything just come with it.
Thanks...
Old 05-16-2011, 08:23 AM
Rep: 1493 Posts: 7,447
The best idea, in my opinion, is to hire a Naval Architect. That will be the the investment that will give you the most for your money. A bad design will make everything else worthless.
Old 05-17-2011, 03:00 AM
Rep: 10 Posts: 4
The Team i didvide into:
2 Naval Architects
3 other ingeneers
2 boat builders
1 sail maker
the rest have degrees in math an fysics
alle are sailors, we are just looking for good ideas, and youre opinion on what is a good set up
Old 05-17-2011, 04:33 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
2 Naval Architects
3 other ingeneers
2 boat builders
1 sail maker
alle are sailors
Then you should teach us, man...
Old 05-17-2011, 05:19 AM
Rep: 10 Posts: 4
Yes it is not the skils there are lacking, but it is always good to have lots of opinions
Old 05-17-2011, 07:17 AM
Lister Lister is offline
Moxy
Rep: 45 Posts: 172
When something doesn't make sense, it's not true usually.
If I read you well, all of you ten have more experience than a lot of the members.
So why asking this vague question? Not in tune with the trade of each of you 10.
What are you really asking, or what do you really want?
Lister
"I always like walking in the rain," he said, "so no one can see me crying."
Charlie Chaplin
Old 05-17-2011, 11:50 AM
Acid house Acid house is offline
Rep: 24 Posts: 15
I wish I had known you needed help...............
Make the pointy end very sharp.
Make the pointy end wide enough to sit behind
Use a very long mast and as big an area of sail as you can
Put a big weight in the bottom so it does'nt blow over.
Drinks holders are best for your champagne......................
There..............that should do the trick
Old 05-17-2011, 12:16 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,597
Hello.
Thanks...
If you're not using the VO 70 rule then do a boat that uses lifting hydrofoils to reduce wetted surface. The winner of the BWR was V3 that used curved lifting foils pioneered by the 60' tri's and others. Look at Vlad Murnikovs Speed dream(pictures below)-his boat uses lifting foils similar to those being pioneered by Hugh Wellborne with his DSS system. Of the two the curved lifting foils may be the best approach. One things for sure: lifting foils have a tremendous future on fast monohulls!
pictures L to R: Speed Dream 35' proto, DSS25(see foil midships just above wl), Speed Dream 100' rendering, V3 with curved lifting foils:
click on image--
New Boat-speed-dream-1-10-11.jpg  New Boat-dss-25.jpg  New Boat-speed-dream-vlad-murnikov.jpg
yes, it is a revolution
