  #256
Old 11-05-2009, 10:51 AM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
I'm not thinking about the kite as "coming home" option only, but as auxiliary power at all times when direction of wind allows. Even as the only means of propulsion if wind's strong enough. Particularly interesting for small commercial fishing boats. Maybe I'll put some work on this idea.
Cheers.
Guillermo Gefaell
Moon Yacht Design
  #257
Old 11-06-2009, 10:15 PM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
Parlier's Project
Another fellow sailor working towards some kite power
http://www.parlier.org/beyond_the_se...a.php?beyond=4
http://www.parlier.org/beyond_the_se...ce_reserve.php
  #258
Old 11-12-2009, 01:04 AM
HISWA Symposium on Yacht Design...paper on kite propulsion
http://www.hiswasymposium.com/pdf/20...nackenberg.pdf
http://www.hiswasymposium.com/symposium_papers.asp
  #259
Old 11-12-2009, 01:26 AM
Boston's Avatar
Boston Boston is offline
Rep: 1360 Posts: 3,257
Cheers.
I was thinking that the if you want to fly a pattern to increase pull then hanging a pendulum off the kite kinda in the same position as were a para-foil pilot would be and using a sprint kinda like a clock does to maintain the motion and period of the swing you would have a nice little automated tracking system for the pattern you wanted to fly
with out all the electronics or at least with a minimum of electronics
that and a simple system of cables similar to U control cables in model airplanes for altitude control and attitude in a pinch
just a thought if it helps any
B
  #260
Old 05-30-2010, 12:10 PM
Kite Sailing the Oceans
Just brought to my attention, this lady (Anne Quemere) kite-sailed across the Atlantic in '06, and now she is onto another adventure in the Pacific.
http://www.anne-quemere.com/
http://www.anne-quemere.com/indexgb.php
New Age Trawler/Motorsailer; Kite assisted PowerYacht-kite-sailing-oceans-anna-quemere.jpg
  #261
Old 05-30-2010, 09:18 PM
Timothy Timothy is offline
Rep: 161 Posts: 166
I forgot where I read it but I think kites are being used to generate electricity through a mechanical linkage from the control lines to an alternator. I wonder if something similar could be adapted to work as secondary function for these "spiniker kites".
  #262
Old 05-31-2010, 06:09 AM
Boston's Avatar
might be easier to just drag a prop behind you
I am skeptical of the deniers diatribe
  #263
Old 08-22-2010, 09:13 AM
The latest measurements made aboard the cargo ship “Michael A.“ of the
Wessels Shipping Company demonstrate how the towing kite propulsion system delivers far more than five times the performance per square meter of sail than traditional wind propulsion systems. With the help of the wind, the 160 square meter kite generates up to 8 metric tons of traction force – this approximately corresponds to the thrust of an Airbus A318 turbine engine.
“Our own measurements show that we were able to temporarily save far more than half the fuel by deploying SkySails in favourable wind conditions,” reports Gerd Wessels (37), managing director of the Wessels shipping company based in Haren/Ems, adding that “alternatively we were able to increase the ship’s cruising speed from 10 to 11.6 knots with the help of this towing kite propulsion.”
Each of the shipping company’s next three new 88-meter, multipurpose sister ships with a deadweight capacity of some 3,700 metric tons and nearly 1,500 kW of power will be fitted with a 160 m˛ kite. With favourable wind conditions, a kite of this size can generate up to 8 tons of traction power. For comparison: in order to reach a cruising speed of 11 knots, these ships require approx. 11 tons of thrust.
...excerpt from http://hiswasymposium.com/symposium-papers
Vessel propulsion using kites
Stephan Brabeck (Skysails Gmbh & Co KG)
Tom Schnackenberg (North Sails A/S)
PDF document
  #264
Old 08-22-2010, 01:33 PM
dskira dskira is offline
Rep: 1305 Posts: 1,363
At 40 mph (Force 8 which is gale force)) the wind pressure is 6 Lbs per square feet.
The kite they talk is 1600 square feet, which means 9600 Lbs of thrust which means 4.5 tons.
I am missing something? How they come to 8 tons?
It must be an explanation I am sure.
As for the comparison with a turbine engine, it is quite inaccurate, you can't mix apple and orange. I am surprise of the lake of seriousness, since by force 0 the kite develop 0 ton of thrust and the turbine still developing the same amount of thrust.
And they always talk about the perfect condition. You do not have perfect condition at sea.
Daniel
  #265
Old 08-22-2010, 01:57 PM
apex1
Daniel
The kite flies a 8 figure steered by computer. That makes the aerodynamic lift add to the pressure forces on the kite.
These 8 tonnes are a proven fact (and not the whole truth, it can be more).
The "perfect condition" is not the every day condition, true, but due to the heighth it is found quite often.
The info provided is BTW not new! It is from 2008. Meanwhile there are several more ships operating with the Skysails system, and ALL are fully satisfied.
I guess we will have affordable, yacht sized systems within the next 3- 5 years.
Regards
Richard
  #266
Old 08-22-2010, 02:31 PM
Regards
Richard
OK, I understand.
Thank you for the explanation.
I saw a picture of the 160 Sq. meter they are talking about associate with the ship Belouga.
This is the picture:
Daniel
  #267
Old 08-22-2010, 03:27 PM
Double the wind speed (apparent wind from 'flying' the kite), quadrupal the wind pressure force.
  #268
Old 08-22-2010, 04:01 PM
Make sense Brian.
When I look at the picture I observed a slight heel. The red paint in the left is slightly less that the red on the right (looking at the picture, the inverse for the ship.) It can be because the vessel turn, or it can be effectively the force of the kite.
Interesting.
Thanks both.
Daniel
  #269
Old 08-22-2010, 04:11 PM
Boston's Avatar
kite moves in a figure eight pattern Daniel, the wind forces on it are higher than if it was just stationary relative to the boat
  #270
Old 08-22-2010, 04:30 PM
apex1
Almost no heel Daniel..............
http://www.skysails.info/
Foil Assisted Cruising Cat Richard Atkin Multihulls 16 10-18-2010 04:30 AM
Designing a boat at age 12 starling718 Open Discussion: All Things Boats & Boating 264 03-05-2009 04:21 AM
Hydrofoil assisted catamarans. Frosty Boat Design 17 04-17-2007 04:47 AM
Hydrofoil assisted V hulls:Where are they? xarax Powerboats 6 03-20-2007 09:57 AM
New cruising catamarans / design style in the computer age Jeff Powerboats 6 05-25-2002 05:40 AM
