  #151
Old 10-06-2008, 05:13 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
Fanie, How is that for brainfarts?
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
  #152
Old 10-07-2008, 08:13 AM
catmando2's Avatar
catmando2 catmando2 is offline
Malaysia bound....soon
Rep: 38 Posts: 167
Originally Posted by juiceclark View Post
If this works out well, we'll try my neighbor's 48' powercat next with this type of deal:
http://www.kit-cats.com/kite/KiteSailPowerboats.htm
I will be very interested to see how that goes as I am again looking at this option for my 50ft cat that I am building.
How do you think it will go with the fixed blade props?
Dave
  #153
Old 10-11-2008, 07:34 AM
Rep: 700 Posts: 3,207
How does any sail boat go with 2 sea anchors being dragged behind ?
FF
  #154
Old 10-11-2008, 12:36 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
You may no get on the plane, Fred
Regards
Fanie
Water ! Just gimme water !
  #155
Old 10-11-2008, 12:42 PM
Fanie's Avatar
Fanie
Hi Mas, ever since you bacame grumpy grampa you cad has deteriorated something terrible You have to take extra classes especially before you start your own boat
Regards
Fanie
  #156
Old 10-11-2008, 06:40 PM
masalai
I thought a quick sketch and scan to get it to you before you had a chance to turn your computer off on your way out to go fishing? and as you can read in another thread??? my main toy is down still with motherboard/ram ? defects in manufacture still......... and am using backup notebook with minimal grunt to work up any CAD package.... and I have been in "withdrawal" soo long I have forgotten how to do cad - - - U know - part of the ageing process - the memory fileing system gets corrupted by distractions like boats, booze and sex....
  #157
Old 10-13-2008, 12:57 AM
eponodyne eponodyne is offline
Rep: 166 Posts: 327
THESE THINGS ARE NOT "DISTRACTIONS!" THESE THINGS ARE THE MAIN EVENT!!!!!
  #158
Old 10-13-2008, 01:59 AM
masalai
Ok, - - - - their importance starts to over-ride all other considerations in a desperate bid to fulfull ones destiny, to have fun, and procreate, as much as possible - as one gets older one becomes more desperate to "cram it all in".....
  #159
Old 01-05-2009, 02:36 PM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
...saw this discussion on another forum...
Originally Posted by Gary
What I am curious about however was your comment that the boat really needed a fair bit of breeze before the kite could be flown by amateurs (sorry, pros) .
Is this a design flaw ? in the kite or the crew ? inherent in the nature of the beast or what ?
Should I not be able to leave the Cape Verdes, put it up and just keep an eye open for St Lucia on the horizon ?
That appears to be more of less what the Germans(edited) are claiming for that odd half spinnaker half parachute thingie.
Enquiring minds would like to know
Pretty much what I expected, too. Figured if I didn't go, they might fly it and stuff it up even worse (would have been difficult), with no one there to give the other side of the story.
Outleaders need about 8 knots apparent to fly. This is often available up high, but not at alunch height. Once you know how to fly them, it is possible to launch them on more of a reach, which allows the apparent to work in your favour. However, until you get to this stage, it is much easier to launch and fly them downwind, when apparent works against you.
As long as the kite always saw 8 knots apparent within 30 degrees either side of ddw, you could hoist it at Cape Verdes, cleat the lines and not worry about it until the other side. What I like about it for shorthanded sailing/racing is that, although it is more likely to fall in the water if the wind changes, it is unlikely to do any harm, just being towed along by the retrieval line (shorter than the flying lines) until you wake up and re hoist it. This compares with a caught aback and/or flogging spinnaker, with the potential to drop the mast and/or capsize the boat.
Remember that these are first generation kites and there is still a lot to learn, particularly about launching them, line handling ( I have a water driven line retriever which works pretty well) and retrieval. They weigh considerably less than a spi, but are heavier than necessary for light air, when a gossamer version with windsurfer kite lines would fly in lighter air. The lines and kite at present are sized to lift the boat out of the water, which is extreme. Given that the drag of the lines is the biggest performance inhibitor, then lighter lines will make a big difference.
If you can organise a J24 or similar sized boat, I will bring my 40 sqm across to Sydney next time I visit (or anywhere else I happen to be visiting) and show you how it works.
regards
rob
  #160
Old 01-06-2009, 03:33 AM
rob denney rob denney is offline
Rep: 318 Posts: 332
G'day,
I posted the above after an abortive attempt to fly an Outleader kite on an 80'ter in this years Sydney Hobart. The abort was nothing to do with the kite.
The offer at the end applies to anyone who is interested in kite technology.
Also, if anyone has any questions on kite powered boats, I am hapy to try and answer them.
regards,
rob
  #161
Old 01-07-2009, 12:15 PM
There are a few other 'kite' discussions over here, postings #161 thru #165...
...including
Originally Posted by Sabahcat
Just got a reply from Kit cats in regard to their kite sail and even suggested they join the kitesail discussion here.
Reply to the email
Thank you for your inquiry.
We no longer deal in the kite sail. We removed it from our website
many months ago.
Strange, I was just looking at it.Yep, still there
http://www.kit-cats.com/kite/300%20m...ite%20sail.htm
  #162
Old 01-08-2009, 02:36 AM
Rep: 166 Posts: 327
Wow, they sure gave up fast.
You make Baby Jesus want to drink Scotch out of the cat bowl
  #163
Old 01-08-2009, 02:45 AM
masalai
backwards it seems as the sites are still open....
  #164
Old 04-19-2009, 02:56 PM
'Sailing'?? Directly to Windward
Here's a interesting digression
So this Dutch artist has created a beautiful propeller-driven skin-on-frame trimaran that only goes directly upwind, without human crew, and set it underway in the western Pacific.
A fascinating project; be sure to check out the construction photos. Some interesting ideas, to be sure, and good for her for actually getting the thing built and launched.
Sailing Directly to Windward
  #165
Old 04-24-2009, 05:15 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 561 Posts: 1,052
which materials cause the least environmental damage to produce for boatbuilding
Foil Assisted Cruising Cat Richard Atkin Multihulls 16 10-18-2010 04:30 AM
Designing a boat at age 12 starling718 Open Discussion: All Things Boats & Boating 264 03-05-2009 04:21 AM
Hydrofoil assisted catamarans. Frosty Boat Design 17 04-17-2007 04:47 AM
Hydrofoil assisted V hulls:Where are they? xarax Powerboats 6 03-20-2007 09:57 AM
New cruising catamarans / design style in the computer age Jeff Powerboats 6 05-25-2002 05:40 AM
