Old 01-15-2004, 08:32 AM
ning
needing help here ...
hey there! i am an industrial design student in singapore. currently i am working on a human-powered transportation project. and i haf some enquiries on the hydrofoil theory.
ok here goes...
lets say i have a surfboard-like kind of board. and i attached a couple of hydrofoil fins on the bottom. then i get a guy of an average weight and height to kneel on top of it holding on to a conventional kayak pedals. and with the pedal, he paddles forward.
now my question is,
1. if he were to gain enough speed, will the 'sufboard-with-hydrofoils' be able to achieve a similar result as those hydrofoil boats and sailboats? in other words, will the board be able to rise up above the water, thus causing less drag and allowing the board to proceed faster?
2. and if it is possible, then what is the estimated speed that he needs to travel?
ya these are what i need to know. i am not any marine engineer, so i am pretty lost at this subject and hope to be able to get some answers from here. your help is very much appreciated! you can reply to this thread, or email me at f@rk.theinbox.org
ya thx alot and hope to get some replies soon!
yours truly,
ning
Old 01-15-2004, 09:03 AM
ErikG's Avatar
ErikG ErikG is offline
Rep: 339 Posts: 397
I suggest that you check out the swedish "Trampofoil"
http://www.trampofoil.com
Other related stuff can be found here...
http://www.foils.org/human.htm
Good luck!
Old 01-15-2004, 11:05 AM
ning
hey thx alot... seen the site... cool stuff!
Old 01-15-2004, 01:53 PM
Suede Suede is offline
Registered
Rep: 10 Posts: 32
Eric...you look much younger today....;-)
Grattis !!!
Olle
Old 01-15-2004, 02:34 PM
ErikG's Avatar
Rep: 339 Posts: 397
Grattis !!!
Olle
Yeah I do don't I? [yummy]
Old 01-15-2004, 10:55 PM
ning
but hey... my problem is still not solved.
i was wondering if there will be problem on the initial of the craft. becos it will human-powered by a set of kayaking paddles.
and wat is the minimum speed that the craft have to attain in order to 'fly'?
ning
Old 03-09-2005, 04:55 AM
NiklasL NiklasL is offline
Student member
Rep: 10 Posts: 37
I remember...
Sorry that I don't know for shure who or when:
I have read somewhere, about a group that tried a simular ting at least 10yrs ago. Maby from the book: "Grogano, James, ICARUS, the Boat That Flies, 1987"
They used a simular one-person boat as pictured and tried to paddle faster than a boat without hydrofoils.
The problem was to remain foilborne with low resistance hydrofoils (small lift area). This because of the nonconsistent propulsion that oars produce.
Their result was that it's not possible to go faster on foils in this boat type with one person and technology available at that time.
So if top speed is not the goal the i assume kayaking on foils (but with sweat involved) is a reality.
/Niklas Lundberg
Old 03-09-2005, 05:02 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Maybe 10 years ago in the "world championship for pedal boats" the winner was a hydrofoil with two hulls (catamaran) for stability at lower speeds and one large foil under the rider and oone smaller in front. When the boat lifted out of the water a small "ski" in the front adjusted the front foiler. The whole thing would ride up and down, oscilating(?) a bit, but it stayed out of the water for severeal minutes, cruising at 10-15 knots! Propulsion was a large slow turning propeller.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 03-09-2005, 07:45 AM
Student member
Rep: 10 Posts: 37
No this one was oar propelled. Propeller is much better.
Old 03-09-2005, 08:09 AM
Rep: 66 Posts: 640
Ning,
No, I don't think it can be done. The thrust is fluctuating too much and you'll have a stability problem as the thrust is alternating from side to side.
But proof me wrong!
Dutch Peter
Old 03-09-2005, 09:03 AM
yipster's Avatar
yipster yipster is online now
Rep: 1027 Posts: 3,269
No, I don't think it can be done with a draggy surfboard eighter. have a look at http://lancet.mit.edu/decavitator/ and using the search button above i'm sure there is more on this subject.
Old 03-09-2005, 10:03 AM
Doug Lord
kayak/ 2 foils only!
You can fly on just two foils like the Moths do but using a kayak paddle,see:
http://www.foilkayak.com/
Also, use the resources of www.foils.org to help you understand what's happening and why.
I would doubt that a "surfboard" could be used because of it's relatively high paddling resistance but as you can see above a kayak sure can fly-quite nicely!
Also check this out:
http://neilprydemaui.com/itemDetails.php?id=48
Still two foils but only one strut....
For some detailed discussion of hydrofoils within the Moth class(THE pioneers in sailing) ,go here and click on message board and then hydrofoils:
http://www.moth.asn.au
Old 03-09-2005, 12:00 PM
yipster's Avatar
another: http://www.airchair.com/
Old 03-10-2005, 03:34 PM
Student member
Rep: 10 Posts: 37
That foilkayak is really mind boggling Dough!
It must be the new materials and cnc-accuracy that made it possible to be more effective than without foils!
Still sweat involved though =)
needing info on gentlemans race boats of the 30's waterman Boat Design 16 09-20-2007 03:59 AM
needing plans allbut1in8 Boat Design 0 03-10-2004 10:59 AM
