Old 12-03-2003, 08:42 PM
ailsnail ailsnail is offline
Rep: 10 Posts: 2
Need more thrust.
Hello,
I have a 9m lifeboat, 3m wide, ~3000kg displacement hull. It has a perkins 50hp@3600rpm, 2:1 gear and a 15"-13" screw.
It is reaching its maximum speed (stern digs in) in still weather, but in moderate waves or headwind the speed degenerates a lot.
I figure I need a bigger prop, and I would like to install an adjustable one. I have my eyes on a three bladed 52cm dia adjustable prop, can I use it with the same engine and tranny?
Will that improve the performance in heavy weather?
Thanks,
Sigurd
Old 12-03-2003, 11:22 PM
Rep: 10 Posts: 2
Oddly, the Surfbaud xls sheet suggests that my pitch on my current setup should be 10, while the local propeller expert says that it should be 13, like it is now.
HP to WATT to THRUST yipster Propulsion 21 06-06-2005 10:56 AM
Thrust tunnel Jasen Boat Design 8 06-05-2005 02:08 PM
Coefficient of Thrust Calculations......Urgent help please! Biomechanist Boat Design 7 11-06-2004 02:08 PM
Prop Thrust Calcs / Bow Thrusters jocko_nc Boat Design 0 04-20-2004 07:32 PM
Help, Thrust Generated By Outboard Guest Boat Design 3 11-12-2003 03:02 AM
