Old 09-08-2011, 01:28 AM
CajunTinMan CajunTinMan is offline
Rep: 10 Posts: 6
Need help with a Trailerable houseboat
I have very little experience with boat building, other than a few small boats just to play around with. What I do have experience with is building campers. I build teardrop campers and have learned to be able to work with little available space and to build them lightweight. I want to build a trailerble houseboat. I am getting close to retirement and am looking for something that my wife and I might be able to spend a week or two at a time on either a protected lake or river. I am retiring on a public servant’s pension, so of course money is no object as long as it doesn’t go over a hundred dollars. Just kidding, but I do need to be frugal. What I have in mind might not work. I was thinking a 32’x8’ hull with a 20’ cabin. It would have an 8’ front two story deck and 4’ aft deck. The cabin would have a vaulted ceiling. I am 6’6 and I was thinking that if I went with a vaulted ceiling I could make my wall 6.5 and do the roof with a 4/12 pitch. I want it to have a fold out bed and a convertible bed/dining table, a micro kitchen ie., stove, small icebox, and a microwave. Pulse a shower and toilet. Basically it would kinda look like a short park model mobile home on the water. I don’t know it would be better on pontoons or a barged style hull. I don’t know if all this would make it to top heavy. The hull either way would be built out of wood and epoxy. Dry wieght W/O hull would be around 4100 to 4600. Please any advice.
Old 09-08-2011, 04:55 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Take a look here:
https://www.boatdesigns.com/Houseboats/departments/7/
Steve
Old 09-08-2011, 06:07 AM
Rep: 756 Posts: 3,328
AN old pontoon boat with aluminum pontoons would be a reasonable base, perhaps found with a trailer.
Outboard power would be fine if a 6K cruise would fit your plans.
FAST will cost big bucks under 1 mile per gallon , 20-40 GPH , depending on how fast you wish to go.
FF
Old 09-08-2011, 06:12 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
Welcome, CajunTinMan, fellow teardrop builder.
http://www.boatdesign.net/forums/ope...-23233-83.html
Hoyt
Old 09-08-2011, 06:28 AM
kenJ kenJ is offline
Rep: 56 Posts: 333
a bit bigger and don't thing they are trailerable, but might get some ideas from here.
http://www.catamarancruiser.com/id16.html
Old 09-08-2011, 07:04 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
I think that a barge type hull would make the most sense as the stability would be the maximum you can get in an 8ft wide package but more importantly,you can build down into the hull and keep the profile a lot lower,i would use the full width for the house and possibly have fold down side decks so you can walk around it and might as well have spuds too. I love this type of boat.
Steve.
Old 09-08-2011, 11:54 AM
Rep: 10 Posts: 6
Teardrops
Thanks Hoyt. Now I just need floats. Lol
You know I thought about the fold down planks but I was trying to think of a way that I could add floats to them to add stability and still be road legal.
Old 09-08-2011, 11:57 AM
Rep: 10 Posts: 6
Oh and as far as speed is concerned, I just need to get from here to yonder the slow lazy way.
Old 09-08-2011, 12:05 PM
Rep: 10 Posts: 6
What would be considered an allowable hight for an 8' wide to keep it stable? I can probably get most of the weight no higher the 4 feet off the deck with the exception of a few cabinets, microwave, portable AC unit, and possible a ceiling fan. The wall will be 2x2 studes, 3/8 OSB with vinyl siding, and 1/8 inch paneling on the inside. The roof would be metal.
Old 09-08-2011, 12:09 PM
Rep: 10 Posts: 6
I had even thought about going solar and using the battery bank as kind of a ballast.
Old 09-08-2011, 06:09 PM
Bamby Bamby is offline
Rep: 811 Posts: 5
I rebuilt and restored a trailerable pontoon houseboat to suit our needs which seem to be similar to yours in many ways. We have the shower, sink, and cooking facilities as your seeking but skipped the instillation of a toilet and it's associated black water issues.
You'll haft to be choosy about your choices of materials and the problematic weight problems that can be associated with it, especially if you're intending on towing your finished boat. I'd question a large battery bank as ballast for this very reason. Our finished boat is tow-able and I've have pulled it up and down the interstate quite a few times, but at least for my tow vehicle it is getting close to the envelope of the comfort zone my pickup is capable of handling well and I really wouldn't want it any heaver.
Hopefully your project will turn out well and you get as much enjoyment out of yours as we have so far enjoyed with ours. If you'd like I wrote a blog about our rebuild and you can review it here, who knows you may pick up something useful for your houseboat project.
Respect Our Outdoor Recreational Resources
Leave No Trace Of Your Passing
"Just Your Footprints in the Sand"
2003 5.3 Chevy P/U
1972 35' Crest Pontoon Houseboat Powered With
2007 90 hp. 4 Stroke Yamaha
Old 09-08-2011, 07:15 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
I bought the plans for a houseboat from Bateau which seem to be close to your specs
http://www.bateau.com/proddetail.php?prod=GT27
I liked it for its room, simple construction and ease of topside remodelling, so us tall guys can make it liveable.
eg
http://schoolroad.weebly.com/project-1.html
Old 09-08-2011, 08:51 PM
Rep: 10 Posts: 6
Yeah Bamby I would like that blog site. Thanks rwatson.
Old 09-09-2011, 06:40 AM
You want to go cruising and have/build a trailer style house on a boat.
Why build a hull, when there are so many setups that can be purchased for 1/10 the cost of building?
If you want to build a boat , that's cool, many have, great hobby.
But if you want to go boating , that's a different hobby.
FF
Old 09-09-2011, 11:15 PM
rwatson's Avatar
Originally Posted by FAST FRED View Post
..... there are so many setups that can be purchased for 1/10 the cost of building?
FF
Where ? where ? Where do i get a "setup" for 1/10 price of building.
Name 2 !
24ft Trailerable Houseboat/Partydeck Mold wenlwca Boat Molds 0 06-18-2011 05:49 PM
Trailerable Houseboats Sean Herron Boat Design 7 11-15-2009 04:42 PM
Trailerable Multihulls JCD Multihulls 333 09-21-2009 07:30 PM
how big is trailerable? martinf Boat Design 12 11-19-2007 04:41 PM
Trailerable hull powderpro Boat Design 0 10-12-2004 09:06 AM
