Old 04-02-2009, 04:26 PM
yğzytkn's Avatar
yğzytkn yğzytkn is offline
Rep: 10 Posts: 4
Need help for my project... (lead me the way)
Hi,
For my project i have to design a motorboat.
Technical Specifications are:
Loa : 23 m
Lwl : 19.5 m
Bmax : 5.8 m
Bwl : 5.1 m
T : 1.55 m
Displacement : 46.5 t
Cв : 0.3
Speed : 25 knot
These are what i have f6r begining. Now what? How can i calculate Am, Awp .. esc..
And how could i form offset table???
Need your help to lead the way
Thanks
Old 04-03-2009, 12:13 PM
yğzytkn's Avatar
Rep: 10 Posts: 4
No one???
Old 04-03-2009, 12:21 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
ygzytkn,
Try Googling your specifications and see what you get.
Good luck!
Tom
Old 04-05-2009, 08:38 AM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
Any book of hydrostatics will do. It's your design project, not ours.
Only shared knowledge can grow.
Old 04-05-2009, 09:09 AM
yğzytkn's Avatar
Rep: 10 Posts: 4
i didnt say do my project i just ask for help
Old 04-05-2009, 03:14 PM
Previous Member
Rep: 0 Posts: 0
It will be planing so the power calculation can be done using Savitsky prediction method:
http://illustrations.marin.ntnu.no/h...ing/index.html
The hull form will be for planing not displacement. Will require something like 1200HP depending on the prop efficiency.
Rick W
Old 04-05-2009, 06:34 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 539
Ygzytkn you have been given the principle dimensions to which you have to work. The Cb is the clue to the way the volume is to be distributed and the speed as Rick has said puts it into the planing boat corner, which points to the hull style. It maybe time to start putting this information to work either on paper or computer. Such things as the relationship between the LOA and DWL and the effect on overhangs are up to you as a designer.Good luck maybe come back with some questions when you have made a start.
Leeboard lead leonabcy Sailboats 5 07-26-2008 05:51 AM
Lead Bulb matalag Boatbuilding 7 06-26-2006 11:10 AM
lead in aluminium ted655 Sailboats 12 09-06-2005 07:24 PM
I need a Lead Naval Architect or assigned Project Enginner ESG Services & Employment 12 11-06-2004 09:29 AM
ketch lead Hannu Rantala Sailboats 17 10-01-2003 07:16 PM
