Old 05-31-2006, 12:36 PM
nigelroe1 nigelroe1 is offline
Need help with my project
Guys, i need to know:
1, I need to know information about cooling systems for maranizing car engines on the engines regular water pump. Also the problems that may occur with the salt water?
2, Currently using a volvo b230 block, we think is a volvo 240 car engine. Can this take salt water through the block and water pump or is there some solution i need to add to coat the block etc.
Thanks
Old 05-31-2006, 10:46 PM
Wellydeckhand's Avatar
Wellydeckhand Wellydeckhand is offline
Previous Member
Rep: 36 Posts: 1,403
There are plenty of information in the sub-forum DIY Marinizing..... Happy hunting.
Old 06-01-2006, 02:02 PM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
For long life you'd probably be best using the engine's current cooling system and a heat-exchanger. Then you can continue to use water/antifreeze in the engine, whilst pumping sea water through the heat exchanger and out to sea. Naturally, you'll need a salt water pump and a header tank on the engine cooling system, but that is pretty easy to do.
Tim B.
Looking for a project, please help joe Marketplace 2 06-26-2005 09:31 PM
My Project WildCherry Sailboats 17 05-13-2005 09:37 PM
New Project gareth Boat Design 0 02-04-2005 04:57 PM
project baby Boat Design 2 11-28-2004 06:20 PM
project donjames Option One 0 09-19-2004 02:50 PM
