Old 05-22-2006, 06:14 PM
Thaddeus Thaddeus is offline
Eccentric
Rep: 10 Posts: 24
Location: 44.93N -93.13W.. not far from the Sweetwater Sea
Need help choosing seam sealant on aluminum sailboat
Hi,
I am building a fast sailing dinghy out of aluminum. I am using an aluminum canoe hull as the basis. Pics at http://www.tc.umn.edu/~austi012/sailboat2.htm.
I am waiting for my special order rivets to arrive, so I have some time; but I am uncertain what sort of sealant to use on the seams. Can anybody suggest something? It almost looks as though Alumacraft used pipe dope on the original seams. I'd need something tough, watertight, resilient, and resistant to extremes of temperature, and of course it should stick to aluminum.. Would something else be a better choice? Silicone caulk, perhaps?
Thanks in advance for any help anybody might be able to provide.
cheers
Thaddeus
Old 05-23-2006, 03:11 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Uhhg....oh well, use Sikaflex 292 or equivalent (like 3M 5200). Make sure the parts are clean and clamp then together lightly. Don't use too thick a bead or it will never cure properly.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 05-23-2006, 04:16 PM
Eccentric
Rep: 10 Posts: 24
Why the "Uhhg...." ?
Old 05-24-2006, 01:40 AM
vishnubaiju vishnubaiju is offline
Rep: 10 Posts: 61
More Stiffeners
Are you going to provide more stiffeners inside the hull. The existing stiffeners were for a narrow boat. Now the width has increased. So more support required in the bottom and sides. What about a watertight chamber inside.Is the aditional center plate (new one) thicker than the sides?
NICE IDEA of widening.
I was thinking in a similar fashion for my Aluminium boat to widen it. It is a welded craft. I will do it.
Old 05-24-2006, 05:56 PM
BillyDoc BillyDoc is offline
Rep: 266 Posts: 421
Hi Thaddeus,
If you clean the aluminum very thoroughly, many 100% silicone based aquarium sealants will chemically bond with aluminum (and glass). Find a Wal-Mart and check out their pet supply section.
You might want to get some of this sealant and experiment with the particular alloy you are using. If you are using lapped seams, for example, the sealant will probably be stronger than any rivet. The stuff is also very tough. I use it for all sorts of things. To clean the aluminum, a fine wet sanding using a detergent solution, followed with a rinse and acetone wipedown usually works . . . if you keep your fingerprints off!
Bill
Old 06-10-2006, 09:06 PM
Eccentric
Rep: 10 Posts: 24
Now I know why the 'ugh'. I set about 250 rivets today. Tomorrow I will be drilling out about 30 to redo them... sigh.
New pix on the updated website referenced above, if anybody's interested.
Old 06-10-2006, 09:47 PM
Eccentric
Rep: 10 Posts: 24
man what a lot of rivets.
I am making a hollow daggerboard out of aluminum... the idea is that it will fill with water when submerged and provide additional righting moment (not much; about 25 lbs. when the boat is at 30 degrees of heel... but every little bit counts in a boat that is only going to weigh about 140 lbs).
Still a lot of hammering to do on the daggerboard. It's not nearly finished.
Old 06-11-2006, 11:48 PM
stonebreaker stonebreaker is offline
Rep: 42 Posts: 438
Originally Posted by BillyDoc
Hi Thaddeus,
Bill
Why would you want to use aquarium sealants? they're exactly the same thing as the 100% silicone you get at Home Depot except the aquarium sealants don't have mildew inhibitors in them.
Stonebreaker
Ph.D in Redneck Engineering - Piling it higher and Deeper.
convert cold molded frame to batten seam planking dave g Wooden Boat Building and Restoration 4 05-03-2006 09:47 AM
Can you help me choosing an engine? neovalk Fiberglass and Composite Boat Building 3 11-16-2005 02:24 PM
Looking for Boatbuilder for aluminum sailboat - Canada Erik Services & Employment 15 02-16-2005 10:38 AM
Aluminum Cruising Sailboat Construction MikeQ Metal Boat Building 7 02-14-2005 03:45 PM
Seam compound-wooden boat alexis Materials 2 07-22-2004 10:41 PM
