  #31
Old 05-26-2011, 03:51 PM
jdnelson97 jdnelson97 is offline
Rep: 10 Posts: 13
On the First 32' boat I was able to fudge on the Hull plate by adding material to the flat pattern before cutting it on the CNC router (using sharpie lines on the orignial outline). I did this in fear of the entry shape not coming out right. The builder new about this and was able to take measurments points I gave him and shave the part down to the correct size once the hull had been tacked together.This was done for the side plates as well. The builder took measurements at each frame from the shear line to the chine and relayed it back to me to fix the parts on the next 32' project. All other parts on the vessel came out with no issues. But I knew there had to be a better way in creating these surfaces in the software or a mathmatical solution. So these parts were not cut as shown earlier. Hope that answers your question.
  #32
Old 05-26-2011, 03:58 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
I understand, thanks. Cheers!
Lofting CD set- Lofting with Arno Day longfellow Marketplace 0 04-24-2009 09:51 AM
Learning Lofting am I ok with this? Tesno8 Metal Boat Building 22 04-16-2008 06:52 PM
Lofting??? Winingar Wooden Boat Building and Restoration 2 07-04-2007 04:35 AM
Lofting elcapitan Boatbuilding 7 04-20-2007 06:37 PM
Lofting LBG Metal Boat Building 7 05-28-2005 09:26 PM
