Old 08-26-2003, 01:39 PM
Heath Heath is offline
Need Help with Aluminum Hull Designs
Can anyone recommend a place where I can get plans for a "23' Contender" type hull design that I might alter for an aluminum boat? In fact any locations for Aluminum hulls would be helpful.
Thanks!
Old 09-23-2003, 05:07 AM
cloudsnowing cloudsnowing is offline
Rep: 10 Posts: 6
what is it tht exactly you needed? i am an aluminium boat builder....
Old 09-23-2003, 08:05 AM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
... and I am a designer with experience in aluminum designs; I have a 22-ft hull design that might be suitable for your needs.
Old 09-25-2003, 09:30 AM
mimmosan mimmosan is offline
Rep: 10 Posts: 2
Hi cloudsnowing,
I have a tread posted on twin rudder vs twin keel. I have been told that retrofitting a steel boat (36ft-47ft) to twin rudder is far easier than a fiberglass one, would an aluminum one fall in the same category as steel?
Thank you
Old 02-02-2004, 05:48 PM
Specmar.Aus's Avatar
Specmar.Aus Specmar.Aus is offline
DREDGIE
Rep: 10 Posts: 53
Heath you can find a bunch of plans for aluminium power boats and landing craft at
Specialty Marine Contractors
(503)543-7562
Stephen F. Pollard specmar@opusnet.com
http://www.specmar.com
Old 02-04-2004, 01:26 PM
trouty
You could try
Computer Design Marine. CDM
http://www.curran.com.au
They supply both plans (also by electronic files delivery) or indeed the whole nested CNC plasma cut vessel construction package if you require.
I've built one, simple & great to deal with before during and after.
When I put mine thru commercial survey they were very helpfull even 12 months later - supplying all the ullage calcs for foam bouyancy etc etc GZ stability curves and so on to satisfy the survey authorities - thoroughly professional co, to deal with...
Some companys don't want to know you after the fact once they have sold you a boat - not so CDM they go above and beyond the call of duty IMHO.
Cheers!
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
hull designs on a 17' powerboat curtis73 Boat Design 6 03-15-2002 09:22 AM
