Old 11-08-2004, 07:14 PM
tibett tibett is offline
Need to calculate the draft of a boat
I am trying to find the draft of a boat. This is what I know.
The boat is 12'wide X 20' long X 10' deep.
The material for the boat is steel and weighs 10.2 lbs per sq/ft.
So I need to find the weight of the boat as a starter.
I will be putting this in sea water using 64.08 lbs per cubic/ft.
Can anyone give me a formula to tie all this together?
Appreciate the help.
Old 11-09-2004, 05:07 AM
Rep: 1623 Posts: 2,344
No formula only hard work
You really need to know what you want for the hull before you can design anything. The use of the vessel would be a good start.
Could I suggest you try and read a book called (I think) "How to design a boat" by John Teal.
What you have to do is
1esign a hull to a desired displacement and ratios
2:Calculate the masses and moments of all the parts in the finished vessel
3: Add ballast and or go back to step 1 and change displacement.
and so on.............
The steel weight should be cubic too !
Mike Johns.
Chrysler Boat Corporation Info captdave311 Powerboats 4 04-14-2008 09:54 AM
Roll Instability on small outboard boat? RThompson Powerboats 14 06-09-2006 02:08 AM
Trying to ID this boat LarryW Open Discussion: All Things Boats & Boating 3 06-23-2005 08:40 PM
Restored boat won't lift/float jetboatjill Boatbuilding 3 05-09-2005 04:23 PM
Boat Design Proj designfreak Boat Design 31 04-15-2005 03:20 AM
