| Need advice on non-destructive testing equipment Need advice on non-destructive testing equipment for FRP/metal/wood for survery purposes. What brands/models are known to work good and have reasonable price? Please share experience. Thanks! |
| This book (in fact the entire website) has good recommendations. http://www.yachtsurvey.com/survey_book.htm
__________________ Best, Charlie |
| My unit is about 20 years old now, it is a simple ultrasonic unit cost about 140 at the time, and is quite reliable in wood. When used if FRP, it does show certain differences in moisture content, I do not believe the figure produced, but they are certainly quite noticable, so there must be some sort of referrece back to the meter. i have tested the unit with brand new laminates, vacuum bagged laminates and resin infusion laminates all the same thickness and all very different readings, but low in moisture. I tried it with a very old glass boat that was out of the water for a few weeks, and it was definately different below the LWL area to above, the weather line decreased as the meter went up the topsides, so i would consider them to be beneficial to surveying. I do not believe the moisture content displayed though as being gospil, but it does have its uses. Particularly, I believe it is relevant to show that there is a problem, it certainly does not show correct percentages, but that is almost irrelevant in real life situations. I think mine is a Thales, but as I am in China working and my meter is at home in Brisbane I cannot check. I do not think it would matter what brand it was, as long as it is only used as a refference piece, not as a gosple recorder.
| I have a TM8812 Ultrasonic tester, as mentioned above, its a guidance. I would not trust it, if not able to open some areas to check real thickness, and use these for calibration and comparison. Absolutely nothing wrong with the meter, just me and my mental state The meter I have, can be calibratet to most "hard" materials, steel, plastic, glass etc.. Have never used it at wood though. Bought it at ebay, from this fellow and experieced fast delivery, good service: http://cgi.ebay.com/Digital-Ultrason...QQcmdZViewItem Sorry for the "advertisement", but I'll get nothing out of it. ![]()
__________________ KnutS "it's dark and we're wearing sunglasses" Last edited by Knut Sand : 05-30-2008 at 02:39 AM. Reason: never used it at wood |
| Sorry Alik, I tried to resist but then again humour..... A good hole borer (makes a plug of what is removed) and a patch-up kit? - or else make the plug from a scrap/offcut of the material used in that part? Logically I cannot think of any ultra-sonic or x-ray that would demonstrate structural integrity better than a core, as most non-invasive methods need be "tuned" to get a base value..... so that you can say "For this reading the probability is that this is what is there".... Metal may be different.... but multiple layers of different stuff??? then it is the integrity and skill of the builder and the trust in that builder - or pay to have a surveyor observe every stage... I intend to go with a builder who will let me be there - even if I only sweep the floors, and to watch progress. - - Then I will really know my boat as well - which, I think, is good and important...
__________________ Try to be helpful... Remember that there are at least two sides for every story... |
| Masalai; your view is quite true, but some of it is pretty destructive. An utrasonic thickness gauge, will only give you (relyably) the measured thickness of homogenous material. So, if you have a hull lay-up with 4 mm GRP on the outside, Divinycell core, and inside with 3 mm GRP, you will only be able to measure 4 mm, and 3 mm. You will not have a clue of the thickness of the core, and this distance, adds strength. (thats where the hole drill comes in..). Also, as Masalai stated; sweep the floors and watch the process. The manufactor may also add some "stringers" (not shure of the name) in the layup of the corematerial, binding the outside laminate to the inside laminate, that you'll probably never see again - ehh hopefully never see again. ![]()
__________________ KnutS "it's dark and we're wearing sunglasses" |
| You need an Xray machine or one of those container sized scanners that customs use - looks right through everthing inlcuding pottery and machine parts. You might be able to hire it! |
| Then (with x-ray) you need to have an expert tune it and he will need core samples to see what he is looking at and then only able to verivy consistency as "apparently similar"
| Easy solved: Borrow a block of hashisj from a suspicious looking kinda fella, rub it on the deck and seats of the boat, deliver it back, remember; you only want the scent of it to stick to the boat, so deliver all of it back. Now get an export/ reimport licence for the boat (motor overhaul or something). Drive it slowly past the costom dogs... Make sure they pick the scent. Now, when the costoms don't find anything, they will call for this X-ray truck, with even a pro to run the inspection for you. Be polite and nice and ask for a copy/ printout of the inspection (say you may need it to aviod further problems up the road). Another pluseffect of this is that you'll probably get all screws retightned by the costoms. ![]()
| Knut Sand, You reign supreme my friend, that would have to be the best advice ever offeren on any international net for a free X ray job...... Ya got ta luv ut!
| This is great advice. I'll even help you out by providing the "product". You'll need to come and pick it up but when you're finished with it rather than sending it all the way back to Australia I'll get you to give it to one of my friends over there.
__________________ Chris Tucker Marine Design Your Boat Your Way. www.ctmd.com.au |
| Spray-up Equipment UK | Joe_Leen | Marketplace | 0 | 03-30-2008 04:35 PM |
| All Must Go: Molds And Equipment | imtryin2 | Boat Molds | 0 | 03-24-2008 03:26 PM |
| New Safety Equipment | odysseyII | Boat Design | 0 | 11-10-2005 08:39 AM |
| Design equipment | Tom.B | Boat Design | 1 | 06-04-2004 10:16 AM |
| non-destructive testing equipment | Boatbuilding | 5 | 10-22-2003 09:40 PM | |
