Old 10-09-2007, 03:18 PM
monrosm@shrewsb monrosm@shrewsb is offline
Amateur Designer
Rep: 3 Posts: 45
Need advice on electro magnetic boat
I need help with a question that has been puzzling me.
It probably has a name, but there is a propulsion sytem that uses a copper bar which is fixed under a boat, a large current is passed through it which causes an electromagnet to produce a vertical magnetic field. Using flemmings right hand rule (first finger field, second finger current and thumb as thrust or force) this should propel the vessel through the water. However it doesnt work. Im trying to answer an A level advanced physics question which asks me why this does not work? Any ideas....have a hunch that it could be to do with water only having a small charge. But i could be way out....any suggestions are helpfull as i have none.
Once again any suggestions helpfull.
Thakyou
Stef
Old 10-09-2007, 03:37 PM
alan white's Avatar
alan white alan white is online now
Rep: 1211 Posts: 3,325
Induction? There are electric automobile charging systems that work on that principle. Something similar should be found in googling water valve that have no mechanical connection from inside to outside the water vessel----- if water didn't interfere.
Another question, would distilled water work best and saline worst?
Alan
Old 10-10-2007, 01:44 PM
Rep: 749 Posts: 1,314
Explain the apparatus more thoroughly. You have mentioned copper bar, large current, electromagnet, and magnetic field.
The electromagnet is presumably some sort of coil wound over a ferromagnetic core, Applying a current to the coil will produce a magnetic field. That field could induce a current in the copper bar which would produce a local magnetic field around the bar (mutual induction). If the current in the electromagnet is DC then a field will develope, but induced current will occur only while the primary current is rising or falling. If applied current is AC then there will be an alternating reversal in the part that has recieved the mutual induction. If any of that resulted in the generation of a force, then the reversing, north/south poles would cancel one another in terms of a force vector.
The electromagnet and the copper bar need to be close together to minimze the affect of the inverse square rule (Coulombs Law).
Even if we could get some kind of directional force to be produced by the copper bar, then we'd need something to react with that force in order to produce propulsion. (Newtons first)
This scenario sounds like the examiners have thrown in a "low ball" question just to mess with your head.
Old 10-10-2007, 02:33 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Sounds about right.
Tom Lathrop
Old 10-10-2007, 04:51 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2069 Posts: 3,574
Stef,
Are you talking about magnetohydrodynamic propulsion?
Here an small and easy experiment: http://www.evilmadscientist.com/article.php/SimpleMHD
Old 10-11-2007, 08:10 AM
RatliffFranklin RatliffFranklin is offline
Rep: 15 Posts: 191
Propulsion
Thakyou
Stef
The magnetic field has to make saltwater flow from the bow of the boat toward the stern to generate forward thrust.
Old 10-11-2007, 01:14 PM
juiceclark juiceclark is offline
Previous Member
Rep: 71 Posts: 373
video somewhere
I saw a show about this on the History Channel once. An experiement was done at a university with a canoe sized craft powered electromagnetically. It worked! But the darn thing just barely crawled along. I can't find the video online anywhere...will look again.
Tony
Old 10-11-2007, 02:09 PM
eponodyne eponodyne is offline
Rep: 166 Posts: 327
So you want the whole lash-up to dissolve into a pile of rust in six months? What kind of efficiency does that bring, other than a tax write-off?
Check out Guillermos' suggested site. There is great fun there, especially for those who do not have enough to think about.
Guillermo; How is it that you are a fountainhead of information and references? Not just on this thread but on many others and many subjects. Thanks for all that neat input.
Old 10-11-2007, 02:26 PM
Guillermo's Avatar
Ingeniero Naval
Hi, messabout! I suppose I just google around very efficiently..
Cheers.
Old 10-12-2007, 03:35 PM
The October 2007 issue of Scientific American has an article about portable micro labs. A flash drive sized unit that is able to diagnose anthrax, HIV, E-coli, influenza, and a lot of other things. The diagnosis chip takes maybe 10 minutes to arrive at conclusions that takes hours in the normal fixed laboratory. Wait a minute guys, I'm getting to the part about boats.
The device takes a droplet of fluid from the individul and squeezes it through a bunch of extremely tiny channels and valves where it is mixed with various reagents, Ultimately delivering a diagnosis. Fluid does not like to go through those tiny channels and some motive power must be introduced. The original experimenters at Univ. of Michigan used air pressure to push the fluid. The method had some drawbacks because of size constraints for the air supply element. Some gee whiz people at MIT rigged up an electrical motivator. The process is called electroosmotic flow. they make the fluid move, despite the resistance of the constrictions. Not only that but they have found that they can persuade the fluid to move with AC current better than with DC. Right; this is mass movement on a nano scale but the science is apparently there. How long it takes to apply the principle to boat propulsion remains to be seen.
No doubt the examiner, the one that I impudently accused in a previous posting, knows more than me. He is demanding much of his student but perhaps that is a way to engender brilliance.
Old 10-13-2007, 01:21 PM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,251
Here's another exotic way to power a boat:
Spray the bow area with a water repellent like wax or silicone and clean the stern with a scotchbrite pad.. The water surface will curve downward towards the bow, while at the stern it will curve upward. The water level at the stern will be higher than at the bow so the boat (according to Archimedes) will move forward. No fuel, no electricity, no noise!
need advice on new jet boat clinchriver99 Jet Drives 8 07-08-2007 09:08 PM
perendev power/magnetic motor bradles1330 Propulsion 13 09-03-2006 04:14 PM
Electric boat advice camglasgow Hybrid 3 04-07-2006 08:09 AM
Advice on boat building zoso Boatbuilding 17 01-06-2006 08:32 PM
Advice on Re gelcoating my boat rich99uk Fiberglass and Composite Boat Building 4 01-01-2006 10:57 AM
