  #301
Old 09-13-2010, 09:25 AM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 602 Posts: 488
Yah Richard for the frame, figured ill get things started
hmm then i need to look again, they cant go over 6 because the laser burns the wood .....
Minimum 18 mm MDF then ... can i use any other wood ?
Thx for ur help Richard much obliged !
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
  #302
Old 09-13-2010, 10:07 AM
apex1
WHICH FRAME?
For the mould or for the boat? Being MDF I assumed for the mould.
We never tried CNC cut in our production, not worth the money for us. I donīt know the technical limitations or alternatives. Except router cut.
  #303
Old 09-13-2010, 10:14 AM
Vulkyn's Avatar
Rep: 602 Posts: 488
For the mold, and yah i meant a router cut ... still navigating through the terms ....
  #304
Old 09-13-2010, 10:55 AM
apex1
Routers go through any common size, find a pro CNC shop, not a bedroom operator with a old plotter table and a cd player laser.
  #305
Old 09-13-2010, 01:03 PM
Vulkyn's Avatar
Rep: 602 Posts: 488
lol .... nicely put Richard yah i have the yellow pages and im going through them so far they the ones I found are "allergic" to MDF or wood and i am sure because it requires more precise setting not just load and cut.
  #306
Old 09-14-2010, 04:05 AM
pedalingbiped pedalingbiped is offline
Rep: 33 Posts: 22
I have been watching your progress and the headaches.
Are you aware that you can change your occupation when your done?
The knowledge your picking up could be life changing.
  #307
Old 09-14-2010, 05:27 AM
Vulkyn's Avatar
Rep: 602 Posts: 488
I hope i can do just that
Thx for following up my thread, soon it will be less theoretical and more practical boat building with hopefully pics (When the plans arrive!!)
  #308
Old 09-14-2010, 06:32 PM
Vulkyn's Avatar
Rep: 602 Posts: 488
After killing a good part of my brain cells, i calculated what i think is the M2 of the boat.
sooo plans say i need 750m of 10x19mm wood.
Assuming the height will be the 19mm then
750 x 0.019 = 14.25 m2 outside surface area x 2 = 28.5 m2 total m2 area
Volume of applied epoxy = 14.25 x 0.00125 (thickness of epoxy per richards calculation) = 0.017813 m3
Denisty = mass / volume
Mass = 1100 (kg / m3 epoxy denisty) x 0.017813 = 19.59 KG of net epoxy not including the gluing part ....
Erhmm feel like i did something wrong .....
  #309
Old 09-14-2010, 06:37 PM
Vulkyn's Avatar
Rep: 602 Posts: 488
The workshop !
Well i had to take the idea of learning autocad just to prepare my workshop with optimal efficiency out of my mind !!(im nuts ..)
I attached a night picture of my hopefully future construction site ...
I was thinking of building a light weight metal structure to create an enclosed working area. There is a lot of wind with sand and the temp is too high to work in the open.
I was thinking to enclose 12 meters x 8 meters.
The ground is tiles and elevated a bit just needs a good clean.
I prepared a list of what i will be needing to get things organized:
1- Electricity, cables, fuse boxes, lighting
2- Sound system for music (ok its a must!)
3- Steel structure with heavy fabric for side covers
4- Tools Electric
5- Tools workshop
6- First Aid kit (i know i will hurt myself some how)
7- Fire extinguisher .. (fires are not fun in a workshop)
8- Fan (bloody hot in summer 45 + degrees)
9- Ventelation pump (get the pesky fumes away)
10- Humidity and temperature gauges
11- Mask / gloves
Dunno if i missed anything else ...
My new baby! 6.8 Meter fiber over wood fishing boat !-dsc05458.jpg  My new baby! 6.8 Meter fiber over wood fishing boat !-dsc05455.jpg
  #310
Old 09-15-2010, 07:40 AM
mihari mihari is offline
Rep: 30 Posts: 48
Here I butt in again...
Instead of building a heavy construction, you could do a green house style construction, like these
http://mortonproducts.com/hseries2.jpg
http://www.exccelgreenhouses.com/wp-...-wireframe.jpg
http://www.igcusa.com/images/coldfra...er-package.jpg
I imagine that green houses in Egypt are not very usefull, thus mass produced frames might be hard to find. Still, you may custom make one. The idea is that the frames can be esily taken away, and placed elsewere (or even re-sold). The skin is usually pvc film, but it can be made from more insulative materials (you want to keep the extreme heat out). Venting it at night (cooler temperatures) and blocking the sun out at day (most of it) would be mandatory to keep the indoor microclimate viable.
  #311
Old 09-15-2010, 07:56 AM
Vulkyn's Avatar
Rep: 602 Posts: 488
hmmm thats a good idea ..... more research and looking then lol
And green houses to exist in Egypt for tropical vegetation (well for growing them in the winter.)
But dont green houses keep temperature in? or could they be regulated ?
Thx for point this out for me, hadn't crossed my mind ...
Please feel free to "butt in" any time, your input is always welcome much obliged
  #312
Old 09-15-2010, 08:23 AM
rasorinc rasorinc is offline
Rep: 828 Posts: 1,305
These $20.00 dollar plans are simple and the Gothic greenhouse gives the most space. http://www.simonsonjh.org/blog/uploa...d-IMG_4003.jpg
http://www.farreachvoyages.com/thebowroofshed.html
  #313
Old 09-15-2010, 08:54 AM
Vulkyn's Avatar
Rep: 602 Posts: 488
Emo mode on
Right thx for all your replies guys this is truly a multicultural knowledge portal ! If only more people would help out like you guys do i swear this world would be a much better place
I am feeling all fuzy inside now knowing i can come here and find help when ever i am stuck.
I could not have even started this project with out the help and support of the great members (and admins )
/ Emo mode off ....
  #314
Old 09-15-2010, 09:44 AM
apex1
If you schedule epoxy work for the night time, a green house/tent might be a alternative. See catbuilder s setup in Florida. It helps curing at high temperatures, but I doubt you can work inside at daytime. And a AC installation will probably come out as expensive as the entire boat hull.
A good ventilated warehouse with insulated roof might be the better way.
Regards
Richard
  #315
Old 09-15-2010, 09:51 AM
Vulkyn's Avatar
Rep: 602 Posts: 488
Yah green house seems the logical solution. Day time will be a problem but fans and proper ventilation SHOULD help. (unless it will effect curing and working), besides the temperature is starting to go down now.
Working at night is a good idea!
The problem of working outside is the amount of dust and sand (plenty of desert close by), so thats not an option.
I was thinking of an iron structure (Ihave one over the roof of a small house there) if pull comes to shove with insulated roof. I will take some pictures of the existing structure i have for better reference.
need used molds for 4 to 8 meter fiber boats memedol Boat Molds 0 12-18-2009 06:51 AM
Surf Baby 17 - a safe little power boat kengrome Powerboats 0 08-29-2007 06:50 AM
How much wood (would a wood chuck ..)? Square feet/meter DanishBagger Materials 8 02-17-2006 09:32 PM
Zoo burglars steal baby penguin kach22i Open Discussion: All Things Boats & Boating 7 12-30-2005 01:41 PM
Baby,it's cold outside riverboathank Open Discussion: All Things Boats & Boating 4 01-09-2004 01:59 PM
