  #136
Old 07-16-2010, 01:13 AM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
Thanks ! 3 it is ! what about the inside 1 or 2 ?
One more thing, what they do is apply a lower thickness matt fiber for the first layer then they apply a thicker fiber on the 2nd. The reason they said that thicker fiber does not stick well to wood and needs a "soft" layer first.
(they use 600 as the thicker version and 300 as the softer one).
If i am to build the exact same boat with epoxy and mulberry, would i need to increase the framing? or would the mulberry planks with epoxy add enough strength to the frame?
I am curies about your work in Turkey! Would there be any possibility for me to travel there and maybe learn a thing or two from a yard there that does good work ??
  #137
Old 07-16-2010, 04:26 AM
apex1
One is enough.
Right
Most probably we will end up with a slightly increased size of frames, still.
No prob. I can make some contacts for you to do a sort of "unpaid apprenticeship".
Regards
Richard
  #138
Old 07-17-2010, 07:57 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
That would be fantastic !!! I will contact you if i will be able to arrange a trip!!
Again many many thanks apex !!
Some pics from another boat being build. I think if i see what this yard is doing and do the complete opposite i should end up with a well build boat!!!
Would it be a good idea to add storage area under the side planks holding the boat? i was thinking that i would use the area as storage space at the same time increase the boats frames. From the top of the plank that goes side ways to the bottom left and right. (dunno if i explained myself properly but i attached a picture on the area i am talking about - the white child like arrows i drew so unprofessionally!!!)
My new baby! 6.8 Meter fiber over wood fishing boat !-dsc05217.jpg  My new baby! 6.8 Meter fiber over wood fishing boat !-dsc05218.jpg  My new baby! 6.8 Meter fiber over wood fishing boat !-dsc05220.jpg
  #139
Old 07-17-2010, 09:55 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Q, Richard, why can a boat not made unsinkable ?
Regards
Fanie
Water ! Just gimme water !
  #140
Old 07-18-2010, 06:08 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Well titanic tried that I would be interested to see the next Unsinkable concept .....
Was my white arrows that bad it scared away every one !!!
On a side note, this is a picture from Alexandria library. This is only a very small angle the building is huge!!
  #141
Old 07-19-2010, 01:26 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
A friends Sea swirl fiber boat was being refurbished, however as i was taking pictures (as usual ) to my surprise i found wood laminated by fiber on both sides. I attached the picture as i was not sure why would a fiber boat builder use wood like that. This is the back rest for a chair and its the area between the engine at the back of the boat.
Also what about the wood cabinet idea i suggested? Any feedback ?
  #142
Old 07-20-2010, 10:14 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Here is a clearer picture of the area i am talking about !
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
  #143
Old 07-22-2010, 01:29 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
A traditional fishing boat in alex
  #144
Old 07-22-2010, 06:36 AM
DennisRB's Avatar
DennisRB DennisRB is offline
Rep: 37 Posts: 435
I don't have any input on the construction your boat. But I just want to say this is a great thread. A lot of newbies just seem to want to argue with Richard and the other pros and continue on with their bad ideas instead of adapting. I'm sure your boat will end up a seaworthy build. Please take a lot of pics when you build it
  #145
Old 07-22-2010, 09:11 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
I hope so !!! This has been an amazing experience so far !! I am falling in love with boats more and more every day !!!
Richard and every one here are great people ... (Where is he lately though? Haven t seen his replies for some time!.)
Thanks for your support! And i do hope my thread helps others as well as myself
A quick update, i just came back from the yard that i will build the boat with. We will proceed as agreed (Mulbery for frames) but they want to use a different wood type for planking (they will call me today).
It took some time to explain that epoxy over wood is not a fantasy and i will build the boat on my responsibility (after some plank testing!).
I will meet with West System epoxy sales rep next Tuesday to get some info on the epoxy and fiber i will be using!
I'll post some pics later today !
This is very similar to the Shoteya i original wanted to build. However this seems like a lake going design rather than sea.
Does any one know if this hull shape can be adapted for fishing at calm sea or if there is something similar to this design?
  #146
Old 07-22-2010, 01:23 PM
apex1
I am sailing! Cannot reply daily.
Take care, West is expensive! We can sure use a local Epoxy instead!
Regards
Richard
  #147
Old 07-22-2010, 02:40 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
lol have fun mate! Missed your feedback
Yah i know but the information i can get from them will help a lot even if i dont build using their epoxy.
Found some local epoxys not sure about the data sheet, so any feedback is highly appreciated!
http://www.isipac.net/EPOXY_industrial_paints.htm
http://www.pachin.net/products.php?cat=2&sub=9
http://www.cmbegypt.com/en/index.php...mapoxy-116-pur (They have a lot of materials, i got lost in finding the one i need :S )
Just a few i found around, still looking for more (im still doing research in that area)
Any ideas about the hull design though?
And have fun !!!
  #148
Old 07-23-2010, 10:51 AM
apex1
And have fun !!!
Thanks I have..............
None of the products above are resins for laminating! All paints, additives or other stuff for the construction business.
But you may ask any of them if they have what we need.
Regards
Richard
  #149
Old 07-23-2010, 11:01 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Regards
Richard
(please correct me if i am wrong) I need a Resin-based epoxy with low-viscosity for composite wooden boat building. I need a slow curing time (since the temperature is high).
Did i miss anything ?
  #150
Old 07-23-2010, 04:36 PM
apex1
Epoxy IS a resin.
You need a "laminating" resin with a slow formulated hardener (curing agent).
The resin should be 100% solid content, no diluents or solvents!
The products you referred to are based on Ep resin, but then modified to be a paint or concrete treatment etc.
The resin must not be specially "tuned" for wood applications.
Regards
Richard
need used molds for 4 to 8 meter fiber boats memedol Boat Molds 0 12-18-2009 05:51 AM
Surf Baby 17 - a safe little power boat kengrome Powerboats 0 08-29-2007 05:50 AM
How much wood (would a wood chuck ..)? Square feet/meter DanishBagger Materials 8 02-17-2006 08:32 PM
Zoo burglars steal baby penguin kach22i Open Discussion: All Things Boats & Boating 7 12-30-2005 12:41 PM
Baby,it's cold outside riverboathank Open Discussion: All Things Boats & Boating 4 01-09-2004 12:59 PM
