Old 08-21-2010, 09:49 AM
floridaboy floridaboy is offline
My Little Cruiser
I'm looking for a design:
easy to build with common tools,
built with materials available at Lowes or Home Depot,
A cruising home for two people,
sleeps two more not so comfortably,
bunks at least 6'6" x 30",
powered by an outboard motor of around 20 Hp,
max beam 8',
proper head and holding tank,
seaworthy for coastwise operation.
Add something if you think I forgot an important requirement, and point me in the right direction, please.
Old 08-21-2010, 10:32 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Houseboat
If you are in Florida a houseboat is your best bet. You can cruise both coasts and down the St Johns further than Palatka, across the State and Lake Okeechobbee and all within protected waters.
There are plenty of good designs for houseboats that meet your requirements.
Old 08-21-2010, 12:02 PM
frank smith frank smith is offline
Rep: 154 Posts: 672
There is a design by Bolger that fits , but I cant remember the name .
30x8 and looks solid.
Old 08-21-2010, 12:06 PM
apex1
max beam 8',
The highlighted points are contradictive.
Either quality or seagoing, both, dirt cheap and seagoing, is not in range.
And Bolger did his plans at a time when the quality of stuff from the suppliers you mentioned, has been a lot higher than today, so, don´t step in that trap!
Regards
Richard
Old 08-21-2010, 01:02 PM
Rep: 154 Posts: 672
you can get good material at a big box limber yard . Many exterior plywoods are of good quality you just have to know what you are looking for . But this argument will go on and on. You should be able to get a good 20 years out of a basic ply boat. Just build it right.
Old 08-21-2010, 01:08 PM
Rep: 154 Posts: 672
Here is a small one, 22" . with an eye on the weather you could use it for limited coastal excursions .
Old 08-21-2010, 05:46 PM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
Nice boat Frank! Look like my bike could go on top!
Can CDX be glassed over and sealed for a boat.....that would last? Can the lanau 1/4" ply be glued togther, over lapped, to build up the material?
Old 08-21-2010, 05:53 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
Again, a little extra expense up front will save you great expense later on.
http://www.intercitylumber.com/Marine_Plywood_Page.php
Hoyt
apex1
What is CDX and Lanau???
Old 08-21-2010, 05:54 PM
hoytedow's Avatar
Resistor
CDX is exterior roofing grade plywood. A-B-C-D being surface veneer quality from best to worst with A being clear or plugged to clear quality, and D having fairly large knot-holes on the surface veneer.
Hoyt
Old 08-21-2010, 05:56 PM
Rep: 154 Posts: 672
It is a case of buyer beware . 1/4 luan is crap, I have seen some underlayment ply that was very good , and much that was crap.
I would do my own research. But marine ply doesn't coast that much in relation to the whole project.
apex1
in short: cr@p.
And Lanau maybe Lauan?
Old 08-21-2010, 05:57 PM
hoytedow's Avatar
Resistor
He probably meant lauan when he said lanau.
Hoyt
Old 08-23-2010, 06:14 AM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Apex gives you good advice. The savings on -to quote his eloquent turn of phrase - crap materials will be negligable in the overall scheme of things.
It takes just as much effort to build a boat out of crap materials as it does to build out materials intended for the job....
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 08-23-2010, 06:27 AM
Carteret Carteret is offline
Rep: 122 Posts: 106
There is a fellow named Dskira on this forum who is building a very nice boat along the same lines as yours. Take a look at his posts. There is plenty of Juniper and Cypress in your area. Buy good materials and set her up right.
Coastal Cruiser Guest625101138 Boat Design 246 03-06-2010 03:58 PM
Independent Cruiser TeddyDiver Boat Design 7 01-07-2008 04:41 AM
Cruiser opinion Ikhanton Powerboats 0 04-14-2004 01:47 PM
Outboard cruiser duluthboats Powerboats 14 01-29-2004 04:49 PM
Cabin-cruiser benladen Boat Design 8 11-27-2003 04:43 AM
