Old 07-10-2008, 07:19 PM
ben2go ben2go is offline
Boat Builder Wanna Be
Rep: 13 Posts: 130
My Design Concept with PICS
Please be kind.I am new to this.I have been researching homebuilt boating and plans.Our lakes are quickly drying up in upstate,SC.Many fishing and ski boats have been running a ground at speed due to unusual currents building up sand bars.I don't need a fast boat or a ski boat.I need a shallow draft recreational boat with the ability to camp 2 adults and 4 kids for a weekend and 2 adults for a week.Here is what I came up with.There's a spec sheet below.This is also my very first time using any design software.I used Google SketchUp.
Flat Water 19
Hull
Length Over All(LOA) 19'4"
Height Over All(HOA) 6'6"
Width Over All(WOA) 6'
Cabin
Length 14'8" including forward birth
Length 11'4" not including forward birth
Height 6' cabin walls can be built taller
Sleeps 4/6 with a canvas cabin encloser on aft deck
Aft deck can be made self baling for fishing.
Draft N/A
Weight N/A
Water Line N/A
Displacement N/A
Estimated Power 10-30HP out board
Useage: Day or weekend cruises with the family on
shallow lakes and rivers.Week long crusies with
the spouse.Shorten cabin and use as a fishing boat.
Building material choosen/off the shelf lumber with
fiberglass and epoxy re-enforcement/hull seathed in
fiberglass cloth/interior and exterior coated with
epoxy for water resistance
These are my ideas and sure to change.Opinions and
advice welcomed.I chose a flat bottom for room and
Our dring up lakes and rivers.We have problems with
bass and ski boats running a ground.I can pull the
motor up and pole my way through the shallows.
My Design Concept with PICS-flatwater19.jpg5.jpg  My Design Concept with PICS-flatwater19.jpg2.jpg  My Design Concept with PICS-flatwater19.jpg4.jpg
My Design Concept with PICS-flatwater19.jpg3.jpg  My Design Concept with PICS-flatwater19.jpg
Old 07-10-2008, 11:28 PM
freesail freesail is offline
Rep: 28 Posts: 41
wow nice.
What program did you use to draw it?
Old 07-11-2008, 12:12 AM
Rep: 13 Posts: 130
Thanks I used Google SketchUp the free educational version.I may get the pro version.Here's the linky. http://sketchup.google.com/ Please watch the tutorials.They really help.
Old 07-11-2008, 04:27 AM
Rep: 2891 Posts: 8,798
Well, other then the aesthetic considerations she'll likely float, though I'd make the beam (width) 8' for increased stability and decreased draft, especially seeing how top heavy she is. With the modest power you're suggested, top speed will be about 6.5 MPH. 15 to 20 HP will get it done, with some reserve left over to punch through chop.
Of course with that much structure exposed to contrary winds, you'll not want to be out when it's rough, plus the flat bottom scow shape will pound much if driven hard into chop.
I'd also recommend you provide some "crown" to the foredeck area so it can shed water (much like what you've done with the cabintop). Also consider some sort of rub rail, so you can meet docks, pilings etc. without scrapping the whole of the vertical flanks across them.
If building in plywood, 1/2" bottom and 3/8" sides will keep her light (important). If you expect much walking around on the foredeck, then make this 1/2", ditto the cabin roof, but 3/8" will work if you don't plan on being up there very often.
Taped seams over well placed bulkheads and furniture would be my recommendation for structural elements. You could build it conventionally over frames, though it will add considerably to her weight. These frames could be on 16" - 18" centers and 1x3's with 3/8" plywood gussets (both sides) at the corners. Don't be tempted to "over build" thinking it'll be stronger, it probably will not be and the weight penalty is something you pay for, each time you fill the gas tank or get into shallow water.
The transom should be two layers of 3/4" plywood or better if 3 layers of 1/2", especially if you later plan to add more power (1.5" is standard for the outboard clamps).
Old 07-11-2008, 07:43 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
Most folks like to be outside when on the water. The aft deck is going to get crowded with 4, especially if you add some chairs. Think you want some more room back there. Nice "out of the box" concept.
Old 07-11-2008, 08:02 AM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
Par.,,,wouldnt the bow be better if it was angled less?,,,i had an old home made square bow,,,,man it PLOWED,,hehe
hehe ,,,,,Jim------>
Old 07-11-2008, 09:49 AM
Rep: 593 Posts: 2,054
Hi Ben,
I like where you are going with your solution. Interesting thinking.
A couple of years ago, I did the design shown below as more or less, a tongue in cheek tribute to Popular Mechanics Magazine and it ran on Duckworks Boatbuilders Magazine www.duckworksmagazine.com A casual glance would show quite a few similarities to your design except my boat has a medium vee hull up front that transitions to a flat run aft and the cabin structure looks like a distorted Art Deco house of sorts.
I was just trying to have a little fun and then something strange happened... I started to get serious queries from the far-flung readers of Duckworks. with most of them asking if a smaller version could be done for the mid-sized American pick-up truck models.
It never went any further than that, but it was sure fun producing the concept and getting mail from all over the place. Here's the direct link to the article. http://www.duckworksmagazine.com/06/...ppin/index.htm
Chris Ostlind
My Design Concept with PICS-camper-boat-bow.jpg  My Design Concept with PICS-camp-boat-truck-front.jpg
Old 07-11-2008, 10:21 AM
snowflying snowflying is offline
Rep: 10 Posts: 5
more research have been done. for example, how about the seakeeping of the ship ? and strength of the stucture of the house
nice idea,
Old 07-11-2008, 12:51 PM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,539
Hi ben2go
here are plans for what you are looking for
these are tried and tested designs
http://www.bateau.com/products.php?cat=27
this one is close to your design
http://www.bateau.com/studyplans/HB1....htm?prod=HB18
enjoy
Old 07-11-2008, 01:00 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
Just so that you know there are other options out there. Hovercraft go on land too.
http://www.amphibiousmarine.com/
Video:
http://www.amphibiousmarine.com/AlaskaPromo.wmv
I do like your boat design.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 07-11-2008, 01:35 PM
the1much's Avatar
huh? hehe ;)
Kach.,,,,,your like a hovercraft drug dealer,,hahaha
Old 07-11-2008, 03:59 PM
kach22i's Avatar
Architect
That's my job around here.
Old 07-11-2008, 04:19 PM
Butch .H Butch .H is offline
Rep: 188 Posts: 631
Chris while you been messing around with designs and stuff have you any for a tender to suit a classic yacht mabe in your back poket ??? Please
Old 07-12-2008, 05:56 PM
chowdan chowdan is offline
lahhhhhh
Rep: 10 Posts: 51
Ben2go,
I live in the Fiji islands and have worked on many ships here. I like the design but I think you would be better off if you had more of a rounded bow(if your looking to get the most room on-board) or maybe have it taper down into a medium deep vee then as you go aft it flattens out to be a flat bottom hull as Chris said his design was. I would recommend at least a 25-40hp outboard if you are going to keep the flat head bow. The flat front will be like trying to push a door through the water. I've seen in rough water wooden boats of this similar design just get hammered, and often they call in asking for a tow. Maybe you should look into a catamaran style as another option?
this is just what i think,
Jordan
Old 07-12-2008, 09:18 PM
Rep: 13 Posts: 130
I plan to do plywood bulk heads and use built in furniture to help keep the hull strong.I had considered going 8' wide and 24' long for more beam and length for a larger rear deck.My plans had changed to bow the front deck same as the roof.My main objective is a shallow draft for protected waters, low power requirements, and fuel usage.I don't need speed.I just wanna site see,fish and enjoy recreational areas with the family.If our lakes and rivers weren't drying up,I'd go for a V hull type full cabin cruiser.Here's a better side view that shows the slope of the bow better.I am planning to do an interior lay out and see how I can arrange everything to strengthen the hull.I'm trying to gather rough dimensions for everything.I just have to remember light and trailer able.It would be nice to do the Bateau.It's a nice design.When I do my next boat,I wanna be able to cruise the ICWs and Florida keys.If gas is still affordable.I looked into hoover craft and almost built one.I need more than they can handle.Not saying they're not loads of fun.I know they are.Thanks for the comments and suggestions.I will incorporate some of the suggestions mentioned here.Hope to report back soon with more.
My Design Concept with PICS-chugger16rightview.jpg  My Design Concept with PICS-flatwater19.jpg5.jpg
Stepped hull design concept batistuvan Boat Design 18 07-05-2007 08:58 AM
design concept seadragon Boat Design 2 06-17-2005 09:09 PM
Concept Boat Design Contest Tad Boat Design 16 09-17-2004 11:13 AM
New Vee Hull Design Pics! sharkeymarine Boat Design 13 06-08-2002 10:38 PM
