Old 11-28-2005, 03:01 PM
tamkvaitis tamkvaitis is offline
sailor/amateur designer
Rep: 34 Posts: 131
My boat any comments?
my new boat..Any coments?
Old 11-28-2005, 04:17 PM
RHough's Avatar
RHough RHough is offline
Retro Dude
Rep: 714 Posts: 1,622
That has to be the nicest solar powered icebreaking minelayer that I've ever seen!
Old 11-28-2005, 06:51 PM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
What kind of bottom does it have? Flat? 'V'? Round?
Is it a sailboat?
Bob
Old 11-28-2005, 10:06 PM
KCook KCook is offline
Rep: 13 Posts: 171
Must be ultra light weight to get away with a transom cutout that deep?
Kelly Cook
Old 11-29-2005, 09:16 AM
Rep: 34 Posts: 131
This is (or I ought to say should to be), an 8 metre sailing boat. I think it can be built from plywood, it's botom is flat, i decided to design it in this way because it is very simple to build and maintain.
Old 11-29-2005, 09:48 AM
Rep: 34 Posts: 131
One more image...I intrested what do you think about this kind of concept...
Old 11-29-2005, 09:58 AM
Rep: 34 Posts: 131
Old 11-29-2005, 11:37 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
The performance will increase hugely if you go for a "Normal" hull-shape. Boats much bigger than 4m rarley ever sail perfectly upright, so the flat bottom is not doing you any favours in normal sailing conditions of 10 to 15 degrees heel. I suspect, also, that the hard "chines" will give considerable difficulty in handling at low speed, and will probably not have nice characteristics at high speeds.
So my advice would be to use a "normal" hull. Don't do anything to the deck-line or the bow. If you're worried about building it, you can always go to thinner sheets of plywood.
General Idea looks nice,
Tim B.
Old 11-30-2005, 04:04 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Vilius, I agree with Tim B.
You can use simple arcs for the stations in the bottom and keep the rest of the design. That will also be easy to build. maybe you can use two layers of 4mm plywood in the bottom.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 11-30-2005, 12:45 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,756
Knock the mast of, stick a handle on the sharp bit and you'd have a lovely coal shovel!
Old 12-01-2005, 02:43 AM
Rep: 3125 Posts: 9,398
Here I am defending a flat bottomed boat again. She's not much like a dory, but looks to be capable of good speed if kept on her feet. Keeping a 26' boat upright will require a high ballast to displacement ratio, crew weight or both. She could be built in plywood easily enough, but it may be difficult keeping it light enough without very thin planking and skinny scantlings. Exotic fabrics may be able to come to the rescue, but at a cost and increased difficulty in application.
The thoughts voiced about round bilge hull forms are well founded, but there are other options. You could build a multi chine or better a radius chine hull and keep the ease of flat panel construction with just a little extra work. I guess it's up to you to decide what you want in this boat. Clearly, the hull shape you have suggests a desire for high performance. Will you be using a crew to hold her down? Boat design is really about answering difficult questions in the requirements you desire, then molding a boat around these concepts as best you can.
We just don't know enough about what you want yet.
Old 12-01-2005, 10:13 AM
Rep: 34 Posts: 131
I wanted to create cheap sailboat which was fun to sail. I decided that flat bottomed boats is the simpliest way of building it. More work means more time and as everybody knows, time is money . If you watched the dwg file you can see that it is quite narrow, I thought that it would increase winward performance, and flat back end of the boat should, increase its downwind performance (corect me if I am wrong, I am just an amateur). Crew of three or four should be perfect for boat like this. I tghout about making the deck wider In the back (something similar like 505 dingy). so that the crew weight would be further away.
Old 12-01-2005, 10:53 AM
netjaws netjaws is offline
Rep: 22 Posts: 73
Heel
If you design it right, your wetted hull can be a perfect V-shape when the boat is at a specified angle of heel. Call this the 'optimum heel angle' and watch it blow every other boat out of the water!
Joshua N Straume
Old 12-01-2005, 10:55 AM
cyclops cyclops is offline
Rep: 33 Posts: 1,059
I think you have Pirated my design which is complete and has had several crew members check it out. Mine is 8' long X 3.5' wide and has a trolling motor in a enclosed motorwell. The 2nd and 3rd graders do not like Pirates.
Old 12-01-2005, 10:58 AM
Rep: 22 Posts: 73
Color
P.S. I think you should also paint it black, that would look really cool.
Joshua N Straume
Hull speed Mike D Boat Design 33 02-27-2011 01:20 AM
fiberglassing plywood boat deck KMD Materials 11 11-09-2005 11:49 PM
Building My Own Boat 66hemi Boat Design 1 10-08-2005 10:51 AM
boat help joejoe Boatbuilding 2 10-07-2005 08:50 AM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 10:08 AM
