Old 01-09-2010, 02:29 PM
fishon91's Avatar
fishon91 fishon91 is offline
Rep: 10 Posts: 43
mud boat plans for the experts
just got about done with the drawings of my dream boat, i literally go to sleep thinking about this boat. i could go on for many more days making small changes and additions. but for now i would like to see what the experts have to say as far as the aerodynamics of the boat, how it will handle in deep water or in mud. i don't plan to run it through deep water too much, but i still want a flat bottom for winching over levees, and ease of building. the drive system is set like a louisiana mud boat, i actually did almost the same exact thing this guy did: http://www.blizzarddesigns.com/mudboat/mudboat.html
biggest difference is the layout of boat and steering on mine is stick, like an airboat.
any questions, please ask. it may be difficult to understand each level of the interior layout of the boat.
DO NOT CRITIQUE THE FORD SYMBOLS!!!!
Old 01-09-2010, 02:30 PM
fishon91's Avatar
Rep: 10 Posts: 43
here they are
mud boat plans for the experts-063.jpg  mud boat plans for the experts-064.jpg  mud boat plans for the experts-066.jpg
Old 01-09-2010, 04:14 PM
Rep: 1493 Posts: 7,447
The views don't seem to correspond. Also, they should all point the same way to make it easier to look at.
Old 01-09-2010, 04:53 PM
fishon91's Avatar
Rep: 10 Posts: 43
they do correspond, the tip of the bow is a little off in the first picture, but of course it's suppose to be centered perfectly. the first picture is a looking down view into the top of the boat, the box between the ford symbols is the cowling over the motor, remember this is a very similiar design to the link i posted. the second picture would be as if the boat was flipped upside down, lookin down at the hull. i'm sorry this picture doesn;t have the swim platform type thing i drew in the other two pics. the third pic is obviously the side of the boat with a radio antenna.
Old 01-09-2010, 05:28 PM
So you are telling me that the bow is vertical and square and the stern rounds up.
Old 01-09-2010, 06:35 PM
fishon91's Avatar
Rep: 10 Posts: 43
no, why would you think that?
Old 01-10-2010, 10:07 AM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
I think Gonzo meant the views are not oriented the same way.
Old 01-10-2010, 12:14 PM
Yes, they should also line up
Old 01-10-2010, 02:28 PM
fishon91's Avatar
Rep: 10 Posts: 43
well, sorry., never perfect
i did say this was my first time drawing real plans. i just figured it wouldn't take much to figure out what was goin on, except maybe the floor plan. anyway could you guys just please look at the dynamics of the boat and how you think it will handle in the water. not sure what i wanna use for a motor, probably just whatever good motor i can run across around 351 or so.
Old 01-10-2010, 04:09 PM
It's difficult to say. What kind of drive are you planning on?
Old 01-10-2010, 05:04 PM
fishon91's Avatar
Rep: 10 Posts: 43
look at the link. it'll have the same drive setup as that boat. here's more links to see what thye driveline will look like:
http://www.airboat-transportation.com/muddhogg.html
Mudboat surface drive prototype
http://www.ronniesairboats.com/mudboats.htm
don't know much about marine transmissions, but so far planning on going with a velvet drive.
Old 01-11-2010, 03:20 AM
I had tried the link before and it wasn't working. I think a surface drive may be a problem if you are hitting stumps on a regular basis.
Old 01-12-2010, 01:14 AM
tom kane's Avatar
tom kane tom kane is offline
Rep: 287 Posts: 887
I have found that flat bottoms on boats loose a lot of strength and are troublesome by sucking to the mud bottom.a slight round or slight v increases strength and gives the hull a movement to break free. A skimming effect. Shallow draught depends on boyancy to lift the weight of the boat to the surface.A small boat can have a greater draught than a bigger boat giving plenty of boyancy to carry motor and passengers. A curved or v bottom gives immersion of boyancy and does not necessarily add to draught.
tomkane
Old 01-12-2010, 05:49 AM
A curved or V bottom adds to draught if displacement is the same.
Old 01-12-2010, 06:45 AM
fishon91's Avatar
Rep: 10 Posts: 43
draught being water line to top of hull? or bottom?
Prop Size For Homemade Mud Motor muddin redneck Props 0 12-16-2009 07:21 PM
Help Needed-Want to bild a mud motor prop simplebobby86 Props 2 10-21-2009 10:38 AM
Mud Motor Drawing mudman DIY Marinizing 3 08-01-2009 08:33 PM
Mud Motor Mark Emaus Inboards 16 06-09-2009 05:10 PM
High Density River Silt & Mud Dredger Wellydeckhand Boatbuilding 16 05-22-2006 12:14 AM
