| Mr. Hacker's "White Cap" Little lunch time project that is finally making way. What do you think? It's all either 3/4" or 1/2" ply. All the structural elements are in 3/4 ply. Frames taper from from 2.5" at the sheer to about 4-5" at the keel. Min bottom frame section is about 3" deep. All the parts are designed to be CNC routed out (still need to quote it) or hand cut from patterns. I suspect that CNCing the parts will save considerable time and improve the accuracy substantially. I was thinking of butt joining the frames with a doubler that is pinned with dowels. (not all the doublers are layed in.) I did the transom frame with little notches for alignment, but that may present more problems then it solves. Opinions? The CAD program is Pro/E. |
| Oh, the missing parts are just the mirror image of a part in the model. No need to add it to the model, just need to remember to order 2. ![]() It will be skinned with ply / resin (WEST system method). Some of the parts (cabin cowls, etc.) are a PITA to model in Pro/E and are to be made out of finer stuff then plywood anyway. |
| Hey, do me a favor? when you get it built and launched and all sorted out, chain it to a stump onshore with a scale in the middle to measure how much thrust your combo is producing. Enquiring minds want to know. |
| huh? Please explain. |
| Find a way to measure how much thrust, in pounds, you've got at WOT. I'm thinking of using the White Cap design for a project and am curious to know what kind of static thrust results in what kind of speed. |
| CMD "project Zeus" VS VOLVO "IPS" | gerard baladi | Pod Drives | 13 | 09-10-2007 10:23 PM |
| Boat "workshop" including a "testing tank" | zmfmd | Open Discussion: All Things Boats & Boating | 0 | 08-08-2007 05:43 AM |
| "juniper" Atlantic white Cedar forsale | cbboatworks | Marketplace | 0 | 11-04-2006 09:29 AM |
| "Free" 3D modeler "similar" to Rhino | CGN | Software | 0 | 05-14-2006 11:56 PM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 03:03 PM |
