| Moving rudder? What are the consideration for moving a rudder to the transom of a sailboat? Frank |
| If the rudder was keel/deadwood hung previously, you'll possibly need to evaluate the CLP (or make rigging adjustments) if the boat displays some bad habits afterward. The same would be true if removing a skeg mounted rudder (including the skeg). If it was a blade mounted under the after portions of the hull, you'll probably have no issues that some minor rigging adjustments wouldn't fix. Lastly, without more information, such as the make, model and year of boat, what will happen is a crap shoot full of generalities. |
| Par , this design has a keel hung rudder with the trailing edge at in line with the transom the rudders trailing edge at the transom. |
| How much separation from the end of the deadwood, will you get if you move it to the transom? If this distance is 10% or less the LWL, then I wouldn't move the rudder. If it's 10% or more and you can stand the blade more upright, then it may be worth the effort if you can also whittle down the deadwood a bit to make a fair flow past it's trailing edge. You'll lose a little efficiency with the top of the blade now out of the water (no hull to act as an end plate), but a better plan form, sectional shapes and aspect ratio can help compensate to some degree. What are you hoping this will accomplish? Is there a prop aperture? A picture would enlighten a lot. |
| What is the reason to make such a radical change?
__________________ Gonzo |
| The mounting system may not be any simpler, you still have a couple of goudgeons or pintles. The main disadvantages are that stern mounted rudders are easy to damage, and that they ventilate. Also, in rough weather they may come out of the water and make you wipe out. I assume the trim tab is for self steering. You can install that on a keel mounted rudder.
| I don't have much issue with a transom mounted rudder, given it's pro's and con's like anything else. It is a much simpler device, doesn't have the leak potential of an inboard setup and if well designed can come reasonably close in preformance of a inboard mount. The real question is what level of preformance are you interested in. If you are so much interested in preformance, then the transom mount may be just the thing. On the other hand a spade through a rudder port would offer several preformance advantages, assuming you have the room to mount this. Ultimately, the amount of separation you have between the deadwood/keel and the new rudder location will determine how much you get from it, though it this is an old CCA style hull, you'll probably not realize very much advantage, because there's just too much boat in front of the rudder. |
| Moving posts | Doug Lord | Forum Questions and Suggestions | 1 | 09-30-2010 04:03 PM |
| Moving the rudder aft | Brent Swain | Sailboats | 16 | 09-01-2010 09:07 PM |
| Moving a rudder outboard | frank smith | Sailboats | 6 | 11-12-2009 07:28 AM |
| Sipbuilder Moving to 3D | stephen gibson | Software | 28 | 07-12-2008 09:00 AM |
| Moving batteries... | firepiper | Electrical Systems | 1 | 10-21-2006 04:14 AM |
