| Mounting of shaft brackets How are shaft brackets (like in the picture below, the upper right one type - only much larger, approximatelly 1m in length) mounted to the hull? ![]() Ughm, I mean ... how are they structurally (oh, boy - my english) fixed? I assume there is a thick plate inside the shell fixed to the transverse frames, and maybe brackets which hold it to the centerline girder? Or am I completely off ... ? |
| It depends on the bottom structure, the length of the shaft, horsepower, propeller diameter, etc.
__________________ Gonzo |
| 700mm Dia is this a ship? |
| For examples, look at blueprints. The installation of shafts and struts is part of the whole design. Studying existing designs is a good way to learn. Looking at the photo you posted, the only safe thing to say is that they will have bolts through the holes. Other than that, there isn't a generic installation.
| Design of brackets | Vinassman | Boat Design | 1 | 11-21-2011 11:10 PM |
| D&D Outboard Brackets | brittanydog | Outboards | 1 | 03-25-2008 03:14 PM |
| D&D Outboard Brackets | brittanydog | Boat Design | 0 | 02-26-2008 11:40 PM |
| brackets | lprimina | Materials | 4 | 09-16-2005 09:04 AM |
| floor support brackets? | drs3317 | Fiberglass and Composite Boat Building | 3 | 07-07-2005 10:53 AM |
