Old 08-08-2008, 06:25 AM
runiuc runiuc is offline
Rep: 10 Posts: 2
Most efficient hull shape?
What is the most efficient hull shape, considering a small sailracer?
Old 08-08-2008, 07:19 AM
Nomad Nomad is offline
Mold Trader/Boat Builder
Rep: 12 Posts: 462
Straight line only? How important is stability? Turning? Weight displacement? There is no clear cut answer as other things come into play other than just the most efficent hull shape.
Old 08-08-2008, 08:56 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
If you are intersted in the fun of racing , you may want to decide on a class. Match racing is the true test of skillls.
It will take a while to master the quirks of whatever Class of Boat you choose, and you can have fun experimenting with tuning and polishing your skills.
Old 08-08-2008, 09:12 AM
Rep: 10 Posts: 2
Purpose: One person, no comfort (low stability) and low displ.
Easy to build and hull material should be plywood
What Im interested in is what shape of hull you should work with.
What different types of hull may fit this purpose?
/Thanks!
Old 08-08-2008, 02:28 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
The fastest hull shape is the one which does not come in contact with the water.
Start looking up foil sailers.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 08-08-2008, 09:46 PM
Rep: 3125 Posts: 9,398
There isn't a "fastest shape", just a difficult set of design compromises that the designer has accepted, as a net result of client desires, during the design process.
If interested in all out performance, in a light weight, small sailboat, then try a Moth foiler. 20 knots is pretty routine, with blasts to 30 occasionally.
If you don't like the idea of "flying" a boat, then a Swift Solo will get your heart pumping.
Kayak an efficient displacement stern shape? pkoken Boat Design 9 01-13-2008 03:11 PM
New efficient Hull for Yachts. cothrang Projects & Proposals 20 07-19-2007 06:52 PM
Which Hull Shape? monrosm@shrewsb Boat Design 8 08-10-2006 10:54 AM
Efficient Hull fish Boat Design 16 05-05-2005 06:15 PM
Hull Shape mrbrown Boat Design 1 08-09-2004 11:24 AM
