Old 08-20-2005, 04:06 AM
waveless waveless is offline
Registered
Rep: 10 Posts: 92
The Most Efficiency Electromagnetic Propeller
Seawater is a conductor, if a conductor is moving in a magnetic field and cutting the magnetic line, the conductor will generate electric current. Using electrical wire to make a short circuit in a ring, the ring is the diamagnetic core. What will happen in this situation? The diamagnetic core will counteract the movement of the conductor.
If using the technology of linear-step motor to make a moving magnetic field under the bottom of the boat, the seawater will be dragged backward, push the boat forward.
Seawater is not a good conductor, but using low voltage electric current and large action area, the problem can be solved.
Old 08-20-2005, 11:10 AM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
Not necessaraly the most economically efficient though. Also, there seem to be gaps still in the understanding of the technology as Japanese researchers have discovered. Definitely an interesting technology, though and it could fit well with photovoltaic generators.
http://en.wikipedia.org/wiki/Magnetohydrodynamic_drive
http://www.physics.brocku.ca/courses...ges/f21019.jpg
Old 08-20-2005, 02:11 PM
Registered
Rep: 10 Posts: 92
JonathanCole,
Thank you for the links.
I think that HMD needs very strong magnetic field to overcome reluctance of the gap, it have to use two pole (N and S). My design use faradism and AC, it may more efficient in the principle.
Old 08-20-2005, 10:34 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Look up the Yamato I, perhaps the most successful MHD craft to date. Supercondutcting magnets seem to be needed to get high enough flux across the propulsion unit for the current to exert any substantial force on the seawater. Problem with AC and water is the tendency to instantly kill everything in the water nearby when the power switch is turned on.
Old 08-22-2005, 07:08 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
Good luck against container ships and docks. Most of them are steel.
Tim B
bigger props faster ship? Peter H Boatbuilding 23 02-01-2010 12:08 PM
Improving Efficiency at 15-20kt joebobb Boat Design 18 09-02-2005 12:12 PM
Propeller Efficiency fredrosse Boat Design 3 03-16-2005 08:10 PM
Hydraulic Propulsion Jmarkley Boat Design 6 10-07-2004 07:21 AM
Analytical propeller theory Guest Boat Design 8 11-12-2003 01:57 PM
