Old 08-12-2004, 04:52 PM
ace rockola ace rockola is offline
Rep: 10 Posts: 3
More of a raft really...
I'm looking to build a stationary raft for an art project. The raft will have to support a pendulum apparatus and pyramidal aluminum struts (all totaling about 300#), and be anchored in about 20ft of salt water. Right now, I'm leaning towards using food grade 50 gallon palstic drums, epoxyd shut/airtight. Can anyone guide me towards the number of drums I'll need to keep this contraption afloat?
Old 08-13-2004, 05:04 AM
dionysis dionysis is offline
Rep: 44 Posts: 256
A cubic foot of salt water weighs about 64 pounds, so every cubic foot of empty space you can submerge below the surface of the sea, will carry 64 pounds of weight.
For example, for simplicity's sake: an empty plastic drum measuring a foot in radius and three feet long will have a volume of 1*1*3.14*3 = 9.42 cubic feet.
It is very hard to push this drum below the water surface. In fact it would take 64*9.42 = 600 pounds to do it. A raft of six of them would all together carry about 3,600 pounds at the surface of the water. You only need to carry 1,800 pounds of weight?, then these drums would float half in half out of the water.
Don't forget to factor in the weight of the drums themselves.
Got the idea?
Old 08-13-2004, 06:34 AM
Rep: 66 Posts: 640
If the structure gets to high, you might want to look at stability too!!
The pendulum is moving, I suppose? You have a big chance that your raft will be rocking!
Old 08-16-2004, 04:13 PM
Rep: 10 Posts: 3
Thats part of the point. I want to have the pendulum crank a ratchet which will engage a small series of those perpetual motion balls that people put on their desks.
I'm going to fill the drums with some type of expanding foam. It'll be lightweight and helps the raft be slightly more risk averse.
Old 08-16-2004, 04:15 PM
Rep: 10 Posts: 3
Originally Posted by dionysis
Got the idea?
Yeah, thanks a lot. Thats the first sensible explanation anyone has given me on this project.
Old 08-17-2004, 05:35 AM
Rep: 66 Posts: 640
That's including the weight of the foam you're thinking about!
Foam will prevent water coming in the drums, but with expanding foam you have to be careful not to damage the drums. It is incredible how much force is exerted while this stuff is expanding.
With making the raft wide enough you'll have no problems with the rocking motion.
Old 10-05-2004, 06:45 PM
Tall Timber Tall Timber is offline
Registered
Rep: 10 Posts: 27
Rafts are sometimes most stable upside down. Make it plenty wide.
Old 03-22-2007, 03:32 AM
djwkd's Avatar
djwkd djwkd is offline
Rep: 51 Posts: 380
is this the way you would do it?work out the weight that there will be (KG is easiest to turn into the buyoncy)turn that into buoyancy,add on the weight of the foam and then put in extra floatation.
Building a raft w/ pvc pipe? Aberamonli Boatbuilding 31 01-08-2012 11:23 AM
building a raft on $75 Captain Mark Open Discussion: All Things Boats & Boating 70 01-04-2010 05:03 PM
Easiest (i.e. cheapest) way to build a raft + rafting disaster! Spyder Ninja Boatbuilding 31 02-20-2009 10:58 PM
Raft for Poker River Run maryann Boatbuilding 1 08-04-2005 05:48 PM
Aluminum dinghy/life raft... bobola Boat Design 3 07-29-2005 09:04 AM
