Old 12-02-2009, 07:48 PM
ociship's Avatar
ociship ociship is offline
Rep: 10 Posts: 12
Mooring Force & Winch Capacity calculation
When calculation for 56K B/C
I have some inform. as below:
- L.B.P = 182.50M
- BREADTH = 32.26M
- DEPTH = 18.30M
- DRAFT AT BALLAST DRAFT = 5.77M
I DON'T KNOW HOW CAN I CALCULATE SOME SHIP'S CONDITION Below:
- WIND PROFILE AREA AT BALLAST DRAFT = ?
- WETTED SURFACE AREA AT BALLAST DRAFT = ?
- WETTED PROFILE PROJECTED AREA = ?
- WIND SPEED DURING MOVING = ?
- WIND SPEED DURING MOORING = ?
Please help me to calculate it and supply some FORMULA and some document to calculate.
Thank you very much.
Old 12-06-2009, 01:19 PM
Velsia Velsia is offline
floater
Rep: 15 Posts: 50
You cannot calculate accurately
wind profile @ ballast draft
wetted surface area @ ballast draft
Wetted profile projected area
Without having the plans for the ship.
This will help you with the wind speeds http://www.sailingusa.info/true_wind_calculator.htm but I don't understand your definition of "mooring"
Out of curiosity could you permit me to be nosey and ask for what reason you are asking this question?
Old 12-06-2009, 06:29 PM
ociship's Avatar
Rep: 10 Posts: 12
Mean "mooring" all ship is included "bollard, anchor, roller, winch...etc." to be used keeping ship or boat at harbour.
Thanks your help, if more, please give me.
$Nothing ventured, Nothing gained$
Old 12-07-2009, 10:02 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Your wind profile area and wetted profile projected area can be extracted from the drawings of the ship: just look at the profile view, take the total area above water, and then the total area below water. The wetted surface should be known from the main particulars table. These aren't particularly precise formulae, that you'd be using, more likely they're empirical approximations. Close enough plus a safety factor is the best you can likely hope for.
Old 12-07-2009, 07:03 PM
ociship's Avatar
Rep: 10 Posts: 12
Thank you for your help, and then finally you kindly tell me "take the total area above water and total below water" is mean plus including "Port side, Starboard side, forward and after area" or only Port side or starboard side?
Power/Resistance Calculation for Planing V-Hull & Fuel/Engine Required Kapitan_Raider Outboards 24 11-26-2008 04:34 AM
mooring shackles & Gal. chain Mychael Open Discussion: All Things Boats & Boating 19 10-14-2008 05:04 PM
Need help, Sailing side force & heel drag ratio! GuestR01312011 Sailboats 2 01-12-2008 02:34 PM
Mooring Bit alpamis34 Boat Design 1 01-08-2007 05:19 AM
Solid mooring float. Mychael Open Discussion: All Things Boats & Boating 17 10-18-2006 02:53 AM
