| mooring door help need Hi, I have to design mooring door in bow part of hull. Mooring door has to section shape adjusted of course to hull shape. Axis of hinges need to be paraler to center line of ship. Unfortunatly it should have sealing around. Hinges should be inside for simple access to pin. Is there any one who can send any information or pictures how to solve that problem. Best regards Pulsar |
| The door does not need to be square , all you need is a straight edge for the hinges. FF |
Edit to add:... Go look at a lot of automobile doors, they have offset axis hinges to swing free of faired body panels. Here is a random website I looked up to show the type of hinge I mean...http://www.customautotrim.com/bodyki..._door_kits.htm If you really need a drawing, I'll see if I can find one.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| barn-door rudder | CaptainDaniel | Wooden Boat Building and Restoration | 11 | 01-25-2009 12:42 PM |
| transom door help | bubtheboater | Boat Design | 2 | 11-12-2007 10:27 AM |
| Transom door..... | firepiper | Fiberglass and Composite Boat Building | 0 | 03-12-2007 07:02 AM |
| Transom door | firepiper | Fiberglass and Composite Boat Building | 3 | 10-06-2006 08:40 AM |
| Fiberglass door | Gregory Walter | Fiberglass and Composite Boat Building | 6 | 11-27-2005 03:32 PM |
