Old 09-27-2004, 11:40 AM
jusembo jusembo is offline
Rep: 2 Posts: 44
Monocoque cold-molding sailboat
Hello,
I start the construction of a 6.5m sailboat in Epoxy-Yellow Cedar, the web-site is:
www.solalelouna.com (the site is in French)
The construction will be "monocoque" hull and roof in one piece (with continue planking)
Does anybody has experience in such construction or has already heared about it?
Thanks for answers (in simple English please)
David
Old 10-02-2004, 05:32 PM
interlude interlude is offline
Rep: 11 Posts: 20
More questions than answers. How thick strip planking? What geometry planking? No fastenings I presume?
I built a 37 ft cedar strip plank boat with 26mm square planking glued and nailed to ribs and together and then epoxy glassed inside and outside.
I had no trouble bending and joining the slightly opened joints as they round the hull. Your tighter radii might be a problem around the deck "joint".
Old 10-03-2004, 10:20 AM
Rep: 2 Posts: 44
Hello Interlude,
Thanks very much for your message
I have given up hope that somebody will made the effort to answer
The planks will be first coat longitudinal +- 5mm to give a strong base and three diagonales of 2mm or 2 diagonal of 3mm
Final thikness should be about 11m
Fastened with stainless staples
For fitting the diagonal planks around the deck joint i will probably bending every plank with hot press before to glue them
I would like to avoid to use fiber glass outside as i'm afraid of "delaminage" (i don't know if it's the right translation from French) after a long period, due to UV radiation and expansion, for example after 20 years...what's your opinion?
It seems nobody has experience with such thing..?
Thanks for answer
Old 10-03-2004, 04:41 PM
Rep: 11 Posts: 20
Hi Jusembo. Your boat looks good. I used Japanese cedar which is very light and the "fibreglass skins" were to strengthen the "composite". Your diagonal planking would be stronger but could still benefit from skins. A fibreglass skin would also ensure a proper barrier to keep worms out and give a stronger surface on deck. Epoxy glassing adheres pretty well to wood as compared to polyester resins, but epoxies must be protected from UV and therefore painted (with a light colour to avoid getting too hot from the sun). Maybe something like 2 diagonal layers of 150 gram twirl instead of the 3rd diagonal wood layer could be considered. Your laminated ribs inside with a glass skin outside would be very strong. Some old epoxy decks I've seen seem to have lasted OK.
Old 10-04-2004, 02:15 AM
Rep: 2 Posts: 44
Thanks for your encouraging
I'm answering on the "Boatbuilding" thread, please follow
http://www.boatdesign.net/forums/sho...9927#post29927
David
CAE Structural support to sailboat design Giovi Boat Design 1 11-03-2007 05:01 AM
Sailboat as a powered cruiser? Bill Fish 6 Motorsailers 28 05-30-2007 06:46 PM
Autopilot System for Sailboat taobsu Boat Design 0 08-09-2005 01:41 PM
Using double layers of marine ply cat28 Materials 5 07-05-2005 01:26 PM
Cold Molding Advice stuart Wooden Boat Building and Restoration 17 01-16-2005 12:39 PM
