Old 02-13-2005, 11:09 AM
jfblouin's Avatar
jfblouin jfblouin is offline
Rep: 24 Posts: 163
Modified Deep V
I'm in design step for building a all FRP 6,7m Zodiac look boat.
You can see one of my study design at
http://boatdesign.net/forums/showthread.php?t=6375 Deep V
For now, I'm looking for V design and I have somes questions at can you see at:
http://boatdesign.net/forums/showthread.php?t=5903 RBB
Yesterday I found this design
Progression boat said:"Hull type is a modified Deep V
Progression’s bottom design, starting at the transom keel, has a seven inch pad running forward. Working from the pad to each side, the design incorporates a 24-degree panel, a three inch lifting strake, a 23-degree panel, a three inch lifting strake, and a 22-degree panel ending with a three inch reverse angle chine. (where the side meets the bottom). This is Progression’s unique Variable-Deadrise Bottom. The benefits of a bottom with this geometric design, as opposed to that of a straight V-bottom, is a stronger and stiffer bottom, creating greater lift in the water. All this adds up to softer entries, a dryer ride, greater stability, and higher speeds in rougher water."
I find this approach interresting for me, but I dont want a high speed boat, only 30-35 knots top speed boat with soft ride and seaworthy.
What do you think about this design.
Old 02-13-2005, 01:40 PM
intrepid71 intrepid71 is offline
Rep: 24 Posts: 49
My understanding is that a convex bottom section will produce reduced impact accelerations compared to an equivalent concave section. I would consider the Progression section to be concave, with the higher deadrise inboard and the lower deadrise outboard. I would recommend reversing that if your really want a soft ride.
Old 02-13-2005, 05:15 PM
jfblouin's Avatar
Rep: 24 Posts: 163
I dont realize that will give a concave section and you have reason. I will calculate a convexe section with the same principle. Thanks a lot. I make a big step forward.
Old 02-14-2005, 01:06 PM
ClarkT ClarkT is offline
Rep: 10 Posts: 96
Shouldn't the convex hull wetter with much higher drag? There must be some data out there on this, but I have not seen it published. Anyone know where to find it?
This variable deadrise angle is very similar to the old SeaCraft 21 hull geometry, which was quite revolutionary in its day.
-ClarkT
Old 02-14-2005, 04:38 PM
jfblouin's Avatar
Rep: 24 Posts: 163
I try to design this test
22 degres bottom, 26 degres middle, 30 degres top
http://boatdesign.net/forums/attachm...tid=2530&stc=1
Small deep water... Sean Herron Boat Design 2 04-12-2005 01:58 AM
Very deep V with strakes or progressive V jfblouin Boat Design 13 02-09-2005 02:17 PM
Variable Deadrise or Modified V? Paul Dean Boat Design 1 01-05-2005 07:09 PM
modified hobie fox hydroski Sailboats 1 03-25-2004 08:48 AM
cg on racing deep vee John Finch Boat Design 2 10-27-2002 08:46 PM
