| Modifications... I am new to this forum and this is my first post. I have a question about designing and building a boat. I want to build a Classic Mahogany Runabout and have found a few plans online, but there are some aspects that I would like to change about these boats; 1. From a Prop with the engine mounted in the forward part of the boat, to a Jet drive where the weight will be moved aft, 2. The lay out of the cockpit, 3. Add a swim platform and some other modifications to the boat. Now my question is should I order the plans for this boat and modify the plans or would it just be easier to design the boat from scratch. The primary use of the boat will just be just to have some fun out on the ocean, but still close to the coast, I am not concerned about having a super high top end and would like to be able to beach the boat with out worrying about damaging the prop (that is why I am choosing a Jet Drive) Any input would be appreciated. |
| similar design Quote:
There is a design very similar to what you want on the forum. Perhaps you can exchange some ideas. http://boatdesign.net/forums/showthread.php?t=13213 |
| he... nice design but have a few mistake... so u have play with it a wee bit. Student
__________________ Student |
| Your design But Westlawn, i thought it was your design? Original quote from the text above: Quote:
| I know. That why I know the bed is way to up in front and the windscreen glass is too pointing up, the windows are not in a straight line.... and others. Cheers Edit: I am not westlawn, but 5554x thanks
| Hi roesler, You'll almost certainly be better off working from plans. Look for something that was designed with jets in mind- monohedral V hulls, with nothing obstructing the last few feet before the pump, tend to fare better with jets than more radical shapes do. I should warn you, although jets do have the advantage of not knocking a blade off the prop when you hit a rock, they don't particularly like a lot of shallow waters. Rocks, sand and weeds can all get sucked into the pump; rocks can do serious damage very quickly while sand tears bearings to shreds. If you have a lot of beaching in mind, an electric kicker or something like the JetPack from Bond Marine (not sure if they're still around, the last info I have is from 1998- ph. 619-579-9763 in El Cajon CA) would be a good idea.
| crowther 10 modifications | lincpike | Sailboats | 1 | 09-06-2004 07:26 AM |
| crowther 10 modifications | lincpike | Multihulls | 0 | 09-06-2004 01:12 AM |
| crowther 10 modifications | lincpike | Fiberglass and Composite Boat Building | 0 | 09-06-2004 01:11 AM |
| crowther 10 modifications | lincpike | Boat Design | 0 | 09-06-2004 01:10 AM |
| Skiff design modifications | byankee | Wooden Boat Building and Restoration | 1 | 05-01-2004 09:43 AM |
