Old 08-14-2006, 08:14 PM
EAP EAP is offline
Rep: 10 Posts: 9
Modern Replication Of A Classic Design
I am in the process of replicating the design of a mid nineteenth century 'sandbagger' sailboat. I have drawings from books with which to work and I think I've hit on a decent lines plan, given comparasions I've made. My quandry is that I am interested in constructing the vessel using modern materials, ie GRP, carbon fiber, etc, and I'm looking for weight comparisions between wood versus fiberglass materials. does anyone have any references they would be willing to share??
Old 08-14-2006, 08:56 PM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
19th century designs can be converted, but it will probably require the lines be revised for a new displacement, reflecting the different construction method and materials. You will have little performance increase if you use the old lines and use new building methods, because the hull will still have to be ballasted down to her sailing lines. This may mean you can have a higher ballast to displacement ratio, a stiffer boat capable of carrying more sail area, but you will still be limited by the antique design lines.
Since you may need major revisions to the lines, which should be left to a qualified designer, possibly a better choice could be a new design. The new lines, complete with construction drawings could look just like an 1800s sand bagger, but incorporate modern features, materials and methods. This boat would not have to carry extra ballast to hold her down and would not be limited to 100 year old plus ideas on what is fast, safe or reliable. The guy that works on my boats is a sailing nut and had a 24 foot sand bagger, he was working on for a customer. He took me out for a ride and the boat carried the sail plan of a 35 foot boat, which he said was cut down a little from original. He, I and four others including the owner and his son did the best we could to hold her down, but were easily over matched in the gusts. The reason I bring this up is, we had a crew of 6 aboard a 24 foot day sailor and it was the best we could do to keep her from capsizing in the gusts. Be careful what you wish for, you just might get it. Sand baggers are wild racing machines from an age of sailor we have never known.
Old 08-15-2006, 04:42 AM
Crag Cay Crag Cay is offline
Rep: 547 Posts: 629
Spirit Yachts built (late 90's?) a 'modern sandbagger' called Fatso the Blagger. See if you can find anything out about her.
Looking for a classic Greek fishing boat design plans Larry Boat Design 16 06-18-2011 08:44 AM
MOdern sailboat design ramon12 Sailboats 1 05-10-2006 06:19 AM
Modern Sailing Boat Design D'ARTOIS Boat Design 18 11-27-2005 09:40 PM
Classic design aitchem Boat Design 3 09-10-2003 05:25 PM
Classic boats: how to design the sail plan? Gades Sailboats 6 08-01-2002 08:30 AM
